Pros | build quality, image quality, ergonomics, look & feel |
Cons | viewfinder |
Rating | 9 |
Price (U.S. Dollars) | 600 |
Years Owned | 1 |
I can recommend this camera: Yes
Value, Features, Performance & Size
great value, exceptional build quality, perfect ergonomics
every feature you need for professional photography
very good image quality, lots of details, good af
Camera Review
After two years of using K200D and occasionally Pentax ME Super I decided to switch to K20D. With K200D I was too limited in certain areas and I knew exactly what I want.
This camera is certainly
not for everyone. I do not consider myself a professional photographer as I treat photography as my hobby but I’m sure It was designed for knowledgeable users that are perfectly aware of what an aperture is, how to use external flashes, what reflector to use when, and so on... More importantly it was designed for people who work with a photography (think before releasing a shutter) and not just take snaps.
Handling & Ergonomics - 10/10 - I use it always with a grip and it’s a perfect combination. The balance with small and big lenses is wonderful. I can shoot for hours and don’t feel any pain nor discomfort even though I mainly shoot with a 2kg setup in my hands and I’m not the strongest man on the planet. In fact 2kg is 3% of my weight, you do the math. There’s knob or button for everything I need and I love the layout. I can switch every settings while looking through a viewfinder. A little drawback - a viewfinder - it’s too narrow and dim for my taste but only a little. One more thing, it’s a tank, the build quality should set an example of how it should be done.
Image Quality & ISO Performance - 8/10 - Also significantly better than K200D but not equally good as the newest gear (no surprise here). Color rendition is really good but sometimes it’s better to adjust white balance manually. Just today I had some keepers, shooting at ISO 3200 f/2.8 but normally I don’t go higher than ISO 400. I’d say ISO 1600 is acceptable by a majority of people and that is plenty to work with.
Overall - 9/10 - For studio and on location work this camera is all you need. In right hands it will do wonders. If you’re here to make photographs the way you want them to be Pentax K20D will help you. It’s a workhorse, and a bargain after K-7 and K-5 took over. Highly recommended.
Why not to buy K20D?
1. If you’re overwhelmed by just looking at all those buttons and knobs,
2. If you want to travel light,
3. If you want the camera to take good photographs for you,
4. If you don’t know if you need one,
5. If you need to make movies with a DSLR,
6. If you can’t live without live-view
don’t even think of buying it. This camera is not for you.
