05-28-2009, 03:45 AM   #16
er1kksen's Avatar
Given that you get a higher frame rate when you attach the battery grip to the D300 due to higher level of power available, I would suspect it might have SOME impact...
05-28-2009, 04:08 AM   #17
QuoteOriginally posted by jct us101 Quote
I don't see how they can compare the D3 to the K-7. They are entirely different categories.
I agree and i woudn't either but the guy is just comparing the fps. Price tag can't be compared either
05-28-2009, 10:30 AM   #18
nulla's Avatar
Wouldnt frames per second depend on shutter speed in burst mode?
Neil
05-28-2009, 10:40 AM   #19
vievetrick's Avatar
Agreed K-7=$1300 / D3=$4400, I would think for another $3000 it would be better & faste. Thats just me.
05-28-2009, 01:31 PM   #20
khardur's Avatar
QuoteOriginally posted by vievetrick Quote
Agree with you too, Pat - and if that test was scientifically accurate, I couldn't justify spending $3k more just for .7 fps faster shutter speed. (according to Alcazar's post on the first page)
Either way, 2.5 fps is already fast enough for me - but the extra speed I know is important to a lot of people - so that's good news for those people.
05-28-2009, 04:25 PM   #21
er1kksen's Avatar
QuoteOriginally posted by nulla Quote
Neil
Only if the shutter speed is low. For any reasonably fast shutter speed the fps would be the same.
05-28-2009, 06:51 PM   #22
Duplo's Avatar
QuoteOriginally posted by Alcazar Quote
I measured the rate of the cameras in this video (not with a stopwatch but by opening the video in a sound editing app)
the Nikon has a rate of 4.97 fps, while the Pentax has a rate of 4.22 fps in the first run and 4.00 fps in the last run.
I know the Pentax is supposed to make more than 5 fps, but isn't the Nikon supposed to make 9 fps??
The question is if the lower rate of the Pentax is due to the unfinished firmware, or maybe the memory card isn't fast enough...?
The D3 has a high and a low burst rate that can be configured individually, thus it may or may not run at 9 fps.
Provided that you have your AF settings and release setting right, then it will do AF-C bursts at 9 FPS and MF burst a little faster (11 fps IIRC)
But you need to have the camera set up right to make it perform and it does take a while to get that right.
Yup, but I plan to run the K-7 alongside my D3s anyway
I would think so too, faster at least.
Better most of the time too, but I regularly have assignments where the size of the K-7 would make it a better or at least a more convenient choice.
05-29-2009, 02:37 AM   #23
nulla's Avatar
QuoteOriginally posted by er1kksen Quote
Thanks for that.. I went checking around to see if there is a minimum shutter speed to base such a test on but couldn't.
Would you have any idea?
Also when checking I found this reply by JCPentax in another forum
> Do you know how fast the burst rate is on the 3 HDR shots? less than
> 1/2 second?
Depends on the shutter speed. If it is fast enough it is firing them at 5.2 fps.
Cheers
Neil
05-29-2009, 12:05 PM   #24
Mister Guy's Avatar
I went a little nuts with my K20D on Saturday. I've manage to reduce 2k candid pictures and 300 portraits to 883 candid and 187 portraits. Will the faster burst speed of the K-7 include any tools to help me improve my frames per second while processing the results of wanton abuse of shutter?
05-29-2009, 01:42 PM   #25
Ash
Community Manager
Ash's Avatar
QuoteOriginally posted by Mister Guy Quote
Indeed!
It may just mean that people reach the 'end-of-life' 100,000 actuation milestone quicker and need to replace their bodies sooner.
Good for Pentax.
05-29-2009, 02:08 PM   #26
nulla's Avatar
Indeed!
Good for Pentax.
Yes good point.. and there will be the push to take 3 hdr shots to produce 1 x image where possible...
neil
05-30-2009, 06:04 AM   #27
Here's Russian K-7 presentation video:
http://www.youtube.com/watch?v=C-PDwlMYMqY
I took audio track from this video and loaded into audio editor, so it was very easy to calculate frame rate of the in video.
Guy has made total of 16 shots in continuous mode there.
First shot started at ~1:18.9, sixteenth shot started at ~1:22.7
So, 15 shots where fired in ~3.8 seconds. That makes 4fps...
camera, dslr, fps, photography, vs
Comparison Tony3d Digital Processing, Software, and Printing 0 10-18-2010 11:13 AM
Teleconverter comparison trev99 Pentax SLR Lens Discussion 0 03-02-2010 08:55 AM
Is there anything to these K-X comparison shots? frascati Pentax DSLR Discussion 17 02-20-2010 04:30 PM
Lens Comparison paolo g Pentax SLR Lens Discussion 1 07-29-2008 03:02 AM
Lens comparison jgredline Pentax SLR Lens Discussion 0 11-03-2007 04:01 PM
All times are GMT -7. The time now is 05:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
