Originally posted by GerryL DOF are really a world apart when it comes to FF and APS-C.
Even if you use the same lens and move back to get the same framing as the FF film cam, the curvature or the juxtaposition of the objects in the chosen space wouldn't just be the same.
A 50mm shot with a FF would have a more spacious feeling than with a backed out 50mm shot with an APS-C, as the space just becomes compressed just like in a zoom lens.
I agree. I bought an FA 35 f/2 to try and get that 50mm look but everything ends up kind of distorted and I can't get the DoF the way I want it. One has to realize that an APS-C sensor is just using less of the image circle than full frame. Therefore, the DoF of a given lens will be closer to what you would get on FF than what its equivalent focal length is.
For example, an
on-line DoF calculator shows that my 35mm lens at f/2 has a total DoF of 0.49' @ a 5' focal distance when mounted to my K10D. The same lens provides 0.73' of DoF on a FF camera. Meanwhile, my 50mm lens at f/2 provides 0.24' of DoF on my K10D and 0.35' on FF. Therefore, even though my 35mm lens
approximates a 52.5mm lens on my APS-C K10D, it gains 0.14' of DoF over a 50mm lens on a full frame camera in the same circumstances. (The difference is 0.04'
greater for a 52.5mm lens on FF, BTW.)
This may not
seem like much but it turns out to be a lot in the shots I take. I'm still waiting for an
affordable ≈ 35mm f/1.4 lens to replace the missing nifty fifty equivalent Pentax's DA lens lineup.
