06-01-2009, 09:36 AM   #1
K2000 Fast Shutter speeds locked out on Flash?
Anyone have the K2000..
can you check something..
Switch to M (manual)
Set the shutter speed to something like 1/1000
Now Press the UP button to pop up the flash.
Look at your shutter speed in the LCD monitor
Has it dropped to a lower shutter speed?
On my k2000 it drops to 1/180 and cannot go any faster while the flash is open.
Anyone have the same problem..
anyone know how the solve this?
Thanks...
06-01-2009, 10:26 AM   #2
Wheatfield's Avatar
It's not a problem. Your camera's flash sync speed is 1/180 second, and it won't go faster if it knows there is a flash present.
06-01-2009, 10:28 AM   #3
This is a "problem" with all cameras canon and nikon included. This is called the camera's "sync speed". For shutter speeds over 1/180th of a second, the shutter cannot move fast enough to expose the entire sensor and close up again. What it does is reveal a small slit of the sensor at a time progressively moving from the top of the sensor to the bottom. As a result since the flash pulse is so fast, only part of the sensor is revealed to catch the flash, the rest is blacked out. The only solution is to get an external flash (afg-540 etc.) that has a high speed sync feature. What it does instead of firing one strong flash, it has multiple pulses of light rapidly in a row so that the subject is constantly illuminated while the shutter is open.
06-01-2009, 10:59 PM   #4
res3567's Avatar
QuoteOriginally posted by kthung Quote
Great explanation! I use to open the back of my K1000 to see if would sync correctly with my flash. It has a vertical travel mechanical shutter and when I saw light for that one split 1/60 or 1/30 of a second, I knew I was in business!
06-02-2009, 07:21 AM   #5
alohadave's Avatar
It would be really nice if the cameras would at least trigger the flash at speeds faster than 1/180, like the other brands do. I can understand why they wouldn't do it, but you can still do creative things with flash even though the shutter is covering part of the frame.
06-02-2009, 12:29 PM   #6
Other brands?
QuoteOriginally posted by alohadave Quote
This question has been floating around a lot in the last few weeks, particularly with regard to the K-7.
I asked my brother, who has a Nikon D200. He tells me that his camera does exactly the same thing as my K10D. There are ways to fool the camera into setting the shutter speed higher, but if the camera recognizes a flash on the hotshoe, or if you use the built-in flash, it won't allow the shutter speed higher than the sync speed.
He didn't try it with the PC socket, so I don't know if the D200 will fire the flash at faster than 1/250, which is the sync speed on a D200.
camera, dslr, flash, k2000, photography, shutter, shutter speeds
SR and fast shutter speeds future_retro Troubleshooting and Beginner Help 10 08-12-2016 01:30 PM
Blur issues at fast shutter speeds Filson Troubleshooting and Beginner Help 2 08-10-2010 07:18 PM
K-7 and shutter speeds in P matthis Pentax DSLR Discussion 10 10-08-2009 02:22 AM
shutter speeds ajaxmgr Troubleshooting and Beginner Help 5 01-03-2009 01:45 AM
Flash & Shutter Speeds .. I don't get it! deludel Pentax DSLR Discussion 8 10-30-2008 01:10 PM
All times are GMT -7. The time now is 06:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
