06-05-2009, 09:38 AM   #1
Noise Reduction Settings in K20D !
What settings do you folks use, I have my camera set to weak. ?
Looking at the samples in DPreview, it looks like the best compromise of high quality and sharp yet removal of some grain. The chroma is what I really don't like, the Luminous I can live with a little better.
Another question ... does the noise reduction just work on JPEG or does this also apply to any raw image you shoot. May seem like a stupid question, but :-)
Thanks,
wll
06-05-2009, 10:18 AM   #2
Marc Sabatella's Avatar
I too found Weak the most pleasing to me on my K200D when I briefly experimented with JPEG. But for RAW, it has no effect whasoever. That's not a dumb question, and there was considerable debate over that when the cameras first came out, but it should be simple enough to do the test yourself and see that it has no effect. You might at first see an effect if you view the RAW image in PPL, because PPL might look at the setting you made (which is presumably saved in the EXIF like other camera settings) and try to reproduce that level of NR, but if you set the NR levels in PPl to be the same for all images, you should find them identical.
camera, dslr, noise, noise reduction settings, photography, question, reduction, settings
Noise reduction settings kiwibird Pentax DSLR Discussion 6 04-30-2010 09:03 PM
K-7 Noise Reduction settings effect Raw Image? Sideways Pentax DSLR Discussion 2 12-23-2009 05:55 AM
Noise Reduction question k20d jbrowning Pentax DSLR Discussion 10 10-22-2008 04:18 PM
K20D and noise reduction Mortox Pentax DSLR Discussion 2 07-15-2008 01:15 AM
k20d \ k200d have a good noise reduction? platinum Pentax DSLR Discussion 4 04-20-2008 01:47 PM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
