06-05-2009, 10:08 AM   #1
Is the Metz 58 AF-1 Flash Compatible with K2000/KM?
I have both, and when I started using the Metz on the K2000, I just can't get a decent picture. The straight-forward A setting on the Metz worked amazing well on my K20D. But on the K2000, it produces way over-exposed, totally washed out, blown out images. If I switch to any of the TTL modes, it under exposes and the WB is all wrong.
I never any problems, much less like these, on the K20D, so I'm wondering if there is something different with the K2000/KM that is throwing the Metz flash off?
Matt! Help!
06-05-2009, 11:52 AM   #2
raz
That is strange, maybe you should try the K-m with a Pentax flash to see if it's doing the same ?
I don't have a K-m, but the Metz 58 AF-1 is working perfectly with my K100D.
06-05-2009, 06:09 PM   #3
mattdm's Avatar
I've never even actually seen a K2000 in person, so I'm afraid I can't help. I'd be surprised, though, if anything has changed that significantly.
06-07-2009, 02:05 AM   #4
I'd check the flash and the cam for correct settings (flash and exp.compensation, metering mode, etc). I don't know the 58, but the 48 works fine on my K-m.
af-1 flash, camera, dslr, flash, k2000, k20d, metz, metz 58 af-1, photography
Are the dedicated Metz flashes fully compatible with current Pentax DSLRs? Eric Seavey Flashes, Lighting, and Studio 6 02-08-2011 06:23 PM
New Metz Flashes Pentax Compatible Christopher M.W.T Pentax News and Rumors 2 08-21-2010 06:15 AM
CTR-301P compatible with Metz 48 AF-1? L(2) Flashes, Lighting, and Studio 2 11-16-2009 11:07 PM
Old lens compatible with K2000? mkgsweims Pentax DSLR Discussion 4 10-31-2009 04:40 AM
Need help with Metz 48 and K2000 LeDave Troubleshooting and Beginner Help 1 08-30-2009 01:47 AM
All times are GMT -7. The time now is 01:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
