04-25-2007, 11:00 PM   #1
skaktuss's Avatar
Memory card error
I just bought a new Transcend 2gb 150x SD card. But my K100D doesn't work with it! At first I thought maybe firmware update 1.02 would help. But after update I got only "Memory card error" on the screen. Card is ok and it works in my card reader without issues. I tried an old 128mb card from a gps device and it worked!
I know that Alvin has this SD card too and he has no problems with it!
04-25-2007, 11:28 PM   #2
It could be that the card has a bad sector or something similar, and the camera is trying to write to that, while that card reader ignores it, try running a disk check utility on the card, if you can, or find some one near by with either a pentax similar to yours or a D80 or D40, so you can check it to see if your cad works in their cameras.
Last edited by Cideway; 04-25-2007 at 11:30 PM. Reason: spelling error that changed the meaning
04-25-2007, 11:36 PM   #3
WMBP's Avatar
QuoteOriginally posted by skaktuss Quote
I have one of these cards, too. I bought it mainly because it was inexpensive - and because some other users in this forum and elsewhere recommended it. At first, I thought it was working fine. But now I'm beginning to wonder. I've noticed two problems.
First, quite frequently lately, when I import photos from the card, one or two photos won't import because the files can't be read or are said to be damaged. NOTE that I never fill the card completely - I always stop shooting when the camera says there's space for at least 10 images. (And if I understand something that I read here recently, that "10" probably means far more than 10, but that's another subject.) I reformatted the card the other day in the camera and I'm waiting to see if I have another problem.
The other problem is that, when I'm using the Transcend 2GB 150x card, continuous shooting just doesn't work as it should with a K10D. Instead of being able to rattle off at least five shots, I might get one or two off, then the camera stalls, then it lets me shoot a couple more, and so on. Don't have this problem using the 2GB SanDisk card or a 1 GB Kingston card.
I should say, to be fair, that I do not have the problem you have. My Transcend card is accepted by the camera and does record the vast majority of my photos fine. And I'm not 100% sure that EITHER of the two problems I describe above is the fault of the card, although the fact that I haven't had either problem when using another card does point in that direction.
Will
04-26-2007, 01:01 AM   #4
skaktuss's Avatar
Thanks for replies! I have to find some other camera to test the card.
04-26-2007, 02:24 AM   #5
I have 2 of these cards, and so far they work flawlessly. Have you tried reformatting the card?
If that does not work, the card has a 1 year warranty, I'd have them replace it.
04-26-2007, 02:52 AM   #6
stewart_photo's Avatar
What you're describing is not all that unusual. Because of slight differences in manufacturing, and slight differences in formating between devices, a card may indeed work in one device and not in another. With six devices using SD cards (two cameras, PDA, card reader, etc), I run into this all the time. Try formating the card using the device it currently doesn't work with (your camera in this case). If that works, then try the card in your card reader. If it now works in both, you're good to go. However, you may find this card simply refuses to work with both devices (card reader and camera). Your only choice at that point is to return it and try another brand, as I've had to do several times.
stewart
04-26-2007, 02:53 AM   #7
benjikan's Avatar
Trnascend 2 GB
I have two Transcend 2 gb 150x cards...No problem what so ever...
04-26-2007, 05:32 AM   #8
If you will search this forum for card reformat, you will find two threads that may help. As I noted in the before and after thread, I never delete images or reformat the card via the computer; only in the camera. I also keep my cards dedicated to the specific camera in which the card was first formatted.
04-26-2007, 06:03 AM   #9
skaktuss's Avatar
I've formatted it in all the possible ways. I'll try to return it!
camera, card, dslr, memory card, photography, sd
Memory card error jaysee15 Pentax DSLR Discussion 5 08-18-2011 09:26 AM
Memory card error chuckdua Troubleshooting and Beginner Help 10 09-29-2010 02:15 PM
memory card error problem cdm807 Troubleshooting and Beginner Help 15 10-17-2009 07:22 PM
Memory Card Error soundview Pentax DSLR Discussion 5 07-23-2008 09:08 AM
Sandisk Memory Card Error- HELP!!!! tasha_22 Pentax Camera and Field Accessories 0 06-30-2007 03:23 AM
All times are GMT -7. The time now is 01:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
