06-08-2009, 12:12 PM   #1
atnbirdie's Avatar
No. of Shots vs ISO Display
I'm familiar with how to change the option of the LCD display in the K110D and K200D cameras between showing ISO setting or no. of shots remaining. There are certainly arguments for each. What I don't recall seeing (or maybe I missed it) is that you can have it both ways.
I am not a high volume shooter, so with a 4GB card even my K200D can hold plenty of shots, so ISO setting is more important than shot count to me. However, once in a while I do like to have a quick status check on where I stand in terms of card capacity. It turns out that with the camera option set to normally display ISO sensitivity, every time you switch the camera off the LCD briefly displays the number of shots remaining. This works on both my K100D and K200D.
06-08-2009, 12:27 PM   #2
WheresWaldo's Avatar
Pressing the OK button does the same thing, and its easier to remember.
06-08-2009, 12:35 PM   #3
atnbirdie's Avatar
True, but what if you have the OK button set to do something else, like center the autofocus position?
06-08-2009, 03:36 PM   #4
klh
klh's Avatar
QuoteOriginally posted by WheresWaldo Quote
Interesting. I have the K20D, and I don't believe that works. I wish there was an easy button to press to check memory space remaining (without turning it off and back on). Anybody know of one?
06-08-2009, 08:16 PM   #5
DAZ
DAZ's Avatar
QuoteOriginally posted by klh Quote
If you change to either Sv or TAv mode and push the OK button (assuming you have the K20D set to display ISO) the ISO display will show estimated shots remaining.
DAZ
06-09-2009, 09:31 AM   #6
klh
klh's Avatar
QuoteOriginally posted by DAZ Quote
DAZ
Thanks DAZ. I am usually in Av or Tv, so I hadn't noticed.
06-09-2009, 10:21 AM   #7
I turn my k20d of to see how many shots I got left, It shows in the top LCD for a quick second before it turns of.
06-11-2009, 07:10 AM   #8
DAZ
Yeah, forgot that this trick doesn't work in all modes, as I am not usually in Green or P modes much.
06-11-2009, 08:20 AM   #9
Marc Sabatella's Avatar
Thanks for pointing out that the # shots remaining flashes when you turn the camera off. Seems I had heard before but didn't think of it as a viable workaround for whatever reason. But it occurs to me I've got an 8GB card in my camera and have probably filled it only once in the years I've had it - number of shots remaining just isn't that important to see all the time. And I turn my camera off to change lenses all the time. I can't myself ever really running into difficulty with this, so I've finally switched over to displaying ISO.
09-29-2009, 12:20 AM   #10
I'm in Av most of the time and have changed top LCD for iso (K20, 1.03). There is something strange, bug or avoid conflict role in Custom Setting No. 23 (defining Av scrolls): only in Av-iso and iso-Av modes pressing OK (on default, not redefined) shows remaining frames, the others shows nothing but iso.
09-29-2009, 12:39 AM   #11
On my K20 I have the LCD set to show the ISO (don't know why since I had it set to 100!) and I noticed that every time you take a shot it briefly displays the remaining card image count, (on the top LCD instead of the ISO setting), so the best of both worlds. Don't know if it works in reverse, if I could find where to change the damn thing I would give it a try!
Found it and no it doesnt work in reverse.
camera, card, display, dslr, iso, k200d, lcd, option, photography, remaining, shots
K-x display # shots in viewfinder opiedog Pentax DSLR Discussion 4 12-06-2009 05:11 AM
Two 1600 ISO K7 SHOTS ;) Christopher M.W.T Post Your Photos! 17 08-16-2009 08:08 AM
shots remaining display? ennoia Pentax DSLR Discussion 6 05-03-2008 01:06 PM
Permanent ISO display on LCD-panel w/ K10D ? Peter_CH Pentax DSLR Discussion 4 04-22-2008 09:38 AM
ISO display in K10D viewfinder ? Confused Pentax DSLR Discussion 5 07-10-2007 05:16 AM
All times are GMT -7. The time now is 06:45 PM. | See also: NikonForums.com, part of our network of photo forums!
