06-19-2009, 06:46 PM   #181
FotoPete's Avatar
Many thanks to both Frank and Falconeye for sharing their many high res samples and experiences with the K-7 (and K20D).
06-19-2009, 08:25 PM   #182
krypticide's Avatar
Thanks! I like the noise reduction that they've employed. It might not be as good as PP results with decent software, but it seems to just make the "grains" bigger and reduces the apparent noise.
06-20-2009, 09:06 PM   #183
Rupert's Avatar
Hello Frank!
Great to hear from you, finally a short review from someone I know and can trust. Excellent photos, as usual....but you can make excellent photos with any camera and the bottom of a fruit jar...we all know that!
If you ever get time, we would love for you to drop by and post some of your work, I'd like to see some updates of your kids.
Flickr: Pentaxians
Best Regards
Rupert (Festus too!)
06-20-2009, 09:17 PM   #184
Marc Langille's Avatar
Nice..... Frank, I am very impressed with the firmware 1.0 images you provided.
Up to ISO 800 is definitely amazing and ISO 1600 is excellent, perhaps little or no NR is needed. I suspect the ISO 3200 will work quite well with NR applied. For my preferred kinds of photography, it is definitely a boon with the high ISO performance and FPS improvement. If the AF performance for indoor/low light situations is as good as perceived, I'm going to really be a happy man!
Regards,
Marc
06-21-2009, 10:25 AM   #185
Stratman's Avatar
Frank, I hope this hasn't been asked yet, but have you tested exposure with "M" lenses and the green button yet? Just wondering if it is improved on the K-7,,,,,If so, I may have to try to trade my K10 and K110 in on one !!
06-21-2009, 01:06 PM   #186
kent's Avatar
Thank you frank for being so unsparing in your efforts. Personally I really appreciate that you post these pictures and answer all questions. Thank you
06-21-2009, 05:28 PM   #187
Thanks Frank! Your postings have been very helpful to me. Great job, sir.
Between this and Falk's blog posts, one can already make a good general assessment of the camera. Who needs to wait for reviews?
To my eye, there's not much difference in high-ISO images between the K20D and K-7, though by no means does that take anything away from the K-7, since it has improved metering, faster AF, better live view implementation, and higher FPS, not to mention a whole range of features to help one spend less time post-processing photos like HDR, lens correction, and so on.
As for me, it looks like I'll be spending on lenses first, since I still haven't been able to maximize the K20D that I have (and it's relatively new, still), though I'll be sure to get the K-7 in the future.
06-21-2009, 07:19 PM   #188
frank's Avatar
Hi Guys, thanks for all your nice comments about my testings It's a great pleasure to share whatever I feel and found about the new K-7 camera. And trust me, it's a great little camera, I'm sure you all would love it
06-21-2009, 07:22 PM   #189
frank's Avatar
QuoteOriginally posted by Rupert Quote
Flickr: Pentaxians
Best Regards
Hi Rupert,
Glad to see you pop in here too I'm sorry that I haven't been to DPR for a long while, might go back there to check out on some old friends there someday soon
I can't shoot through the bottom of a fruit jar, that's why I always use good lenses But thanks anyway for your compliment.
I do have some of my kids photos, will post some when time comes.
Cheers!
Frank
06-21-2009, 07:35 PM   #190
frank's Avatar
QuoteOriginally posted by Stratman Quote
Well, actually I've got used to use M mode and do some testing shots to get the right exposure when using a manual lens on my K10D and K20D, probably due to their unreliable metering w/ the green button. I hadn't really done any exposure test w/ a full manual lens on the new K-7 camera.
Since you asked, I did some very quick test this morning w/ a K10D and K-7, and an good working condition M50/1.4 lens (no stick aperture blades or whatsoever), both indoor and outdoor.
Here are outdoor testing results, ISO set to 100 on both cameras, used M mode and pressed greet button to meter, metering mode set to spot metering (but I guess it doesn't make any difference if set to other mode since it's a full manual lens). All shots were taken handheld but I tried to focus at the same spot.
Since it's partly cloudy in the morning, the brightness wasn't the same when I tested the two cameras. But this won't affect the actual metering accuracy I guess.
Here are a couple of indoor testing shots, same as the outdoor testings except ISO was set to 400 on both cameras:
I did several metering tests (by pressing the green button several times) before I took each shot, just make sure it's not some random metering result. Seems the M50/1.4 lens works pretty well on K-7 w/ the green button for metering. How do you think?
06-21-2009, 09:04 PM   #191
krypticide's Avatar
Wow, the difference is huge!
06-21-2009, 09:41 PM   #192
SelrahCharleS's Avatar
Thank you Frank for all of your tests. I'm happy to see M lenses working as intended. I had no idea they were that bad on the K10. It's good to see the exposures seem to be more consistent with the K-7 since I use M lenses primarily. I also enjoyed your photos and found the noise test very helpful too.
And now for a question. What are your thoughts on the strap that comes with the K-7? I absolutely hate the strap that came with my *ist DS because of the fake leather or whatever it is they use for 'padding'. Judging by your photos it looks like the strap you have on the K-7 doesn't have that stuff and is just woven cloth. Is it comfortable? I don't really have any experience with the newer Pentax DSLRs so maybe it is improved on them too, but from the photos you posted it actually looks like a decent neck strap.
06-21-2009, 10:36 PM   #193
frank's Avatar
QuoteOriginally posted by SelrahCharleS Quote
Sorry I don't know what kind of shoulder strap would be bundled w/ K-7 camera. The one in my photos are my own strap which came w/ my Super Program camera (the strap is a Special Edition for SuperA camera which was awarded as European Camera of the Year in 1983).
But judging from the photos in the following link, I think the shoulder strap will be more or less the same as the one comes w/ K10D/K20D:
宾得K-7超简单开箱 - Windows Live
06-22-2009, 01:58 AM   #194
frank's Avatar
Took some macros w/ the new K-7 over the weekend. Here are two of them:
More macro photos can be found here at the photo forum:
Some macros w/ a beta K-7 camera (imgs)
06-22-2009, 02:18 AM   #195
Awesome photos frank.
Your range of photographic talent is very impressive.
The lense you used for these macro shots seems pretty awesome too.
af, awb, battery, camera, dslr, fa77, k-7, lens, light, photography, photos, tungsten
Carry-on camera gear for US bound flights - any experiences? SF1 Travel, Events, and Groups 4 03-05-2010 07:03 PM
Beach Camera experiences? Good or Bad? rdrum76 Photographic Technique 12 01-10-2008 11:06 AM
My London experiences(lots of pics) vdubbin099 Post Your Photos! 8 10-09-2007 11:25 AM
Unusual camera bags (+11 imgs) hinman Pentax Camera and Field Accessories 3 09-07-2007 06:10 PM
Henrys Camera Show (Lots of Pics) FotoPete Pentax SLR Lens Discussion 5 05-06-2007 08:09 PM
All times are GMT -7. The time now is 11:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
