06-23-2009, 06:13 AM   #211
QuoteOriginally posted by frank Quote
BTW, I just uploaded two very short video clips taken by K-7 and F*300/4.5 here:
http://www.youtube.com/watch?v=0kJ__JcfVR4
http://www.youtube.com/watch?v=meT6MONXcfw
You guys can do better 'cause I'm really bad at shooting videos ...
Thanks again Frank for your great work.
I'm very curious to see if the K7's video has the same 'jello' motion problems reported for the Nikon D90/D5000 - such as cameralabs.com reported in their review of the D90:
Nikon D90 review Cameralabs features: Movie Mode
The D90’s video mode also suffers from motion artefacts often referred to as wobble, skew or jello. This is a well-known issue with CMOS sensors with rolling shutters which record each frame from top to bottom before returning to the top again for the next one. Should the camera or subject move during this process, the image can appear to tear, skew or wobble. Now many video cameras, both amateur and professional, employ CMOS sensors, but some suffer more from this effect than others. Sadly the D90 suffers more than most. Panning or zooming, fast-moving subjects or simply handheld work can often result in very undesirable artefacts.
I hope the K7 avoids this issue. It sounds ugly.
06-23-2009, 08:18 AM   #212
QuoteOriginally posted by KungPOW Quote
Frank is showing that the K-7 with a manual lens has better "green button" metering then does the K10D.
The test has nothing to do with details, or highlights or blocked shadows. All he is showing is that there is less exposure variation between open aperture and closed aperture with the K-7 then with the K10D.
Although it is not perfect, it is a great deal better.
Thanks Frank!
Ahhh ok, that makes since.I never use green button metering with my manuals which is why I didn't quite understand what was going on.My appreciation to Frank and Falconeye as well.
06-23-2009, 01:38 PM   #213
Ratmagiclady's Avatar
That's... A pretty darn nice improvement in the high-ISO, whatever versions we're looking at.
I could get behind that.
06-23-2009, 02:46 PM   #214
Holy jeez.
800 on the K7 is as good as 200 on my *istDL.
1600's comparable to 400 on mine.
3200 isn't great but it's actually usable. 3200 on the *istDL is sandpaper, good only for B&W or Sepia shots.
06-23-2009, 04:57 PM   #215
QuoteOriginally posted by Volvo244T Quote
Holy jeez.
Or 100 on my K20
06-24-2009, 02:29 AM   #216
frank's Avatar
Hmm, I don't know. I didn't see that problem here. But I didn't take many video w/ the camera ...
06-24-2009, 02:34 AM   #217
frank's Avatar
The retail K-7 will be here in several days. Let's wait until then so we can really see how well the actual camera performs
06-24-2009, 03:19 AM   #218
SpartanWarrior's Avatar
Also nice video clips Frank seems it does really good, anyway what SD card would be great with the K-7 i have a sandisk extreme lll 8gb but i think it will not be enough, would the 16gb be better? also on the SR is it does it work better than on the K20D? thanks
06-24-2009, 04:41 AM   #219
Frank, did you by any chance try long exposures (longer than 30 seconds)?
I was reading the K-7 manual that Ned B published on his blog and this seems to indicate that Dark Frame Subtraction (called Slow Shutter Speed NR in the manual) can only be turned off for exposures shorter than 30 seconds:
Reduces noise during long exposures.
On: The camera determines the conditions such as the shutter speed,
sensitivity, and internal temperature, and automatically reduces
noise as necessary.
Off: Reduces noise only when the exposure mode is set to B and the
shutter remains open for 30 seconds or more
So I guess astroshooters who were hoping for a better camera for their hobby will be disappointed? Can you confirm this?
tx, Wim
06-24-2009, 05:24 AM   #220
frank's Avatar
QuoteOriginally posted by SpartanWarrior Quote
I used 4gb Sandisk Extreme III and Ultra II SD cards w/o any problem. 8gb extreme III cards should be perfectly fine unless you take a lot of videos
06-24-2009, 05:25 AM   #221
frank's Avatar
QuoteOriginally posted by Ishpuini Quote
tx, Wim
Sorry Wim I never tested long time exposure. The longest time I tested was about 10s.
I've returned the testing camera, can't do any test anymore But the retail one will be here next week. Let's wait for several more days
Cheers!
06-24-2009, 06:05 AM   #222
falconeye's Avatar
Well, the sentence says that "B and >=30s" are required, not "B or >=30s". This is a big difference and let's hope that the person who translated it was aware of this
EDIT: it makes no difference at all because >30s implies B
As for testing ... alpha test cameras always act like in OFF mode as described in the manual.
EDIT:
Initially, the above sentence claimed that test cameras wouldn't do DFS at all. But I was wrong.
Last edited by falconeye; 06-24-2009 at 07:24 AM. Reason: changed P into B, remark on test cameras corrected
06-24-2009, 06:45 AM   #223
Well, the sentence says that "P and >=30s" are required, not "P or >=30s". This is a big difference and let's hope that the person who translated it was aware of this
As for testing ... alpha test cameras don't do Dark Frame Subtraction even if it is switched on and even with fw 1.0. Maybe, I should try to keep mine for astro-photography?
Sorry, my mistake... The manual reads B and more than 30s. The P got in there because of a copy/paste problem between Acrobat reader and Firefox.
So if in Bulb and more than 30 seconds: no Dark Frame Subtraction. Normal actually, since B is the only mode where longer exposures than 30s are possible...
Perhaps you should indeed keep the alpha test cam, and sell it to the highest bidding astroshooter...
Wim
06-25-2009, 02:25 AM   #224
Class A's Avatar
The clips attracted posters (at YouTube) who ask whether they are seeing AF speed. Perhaps you should clarify.
Thanks for all the work!
06-25-2009, 03:00 AM   #225
Can someone tell me if they know or have a link where it says whether or not, in VIDEO MODE, you can adjust Shutter speed or ISO?
af, awb, battery, camera, dslr, fa77, k-7, lens, light, photography, photos, tungsten
Carry-on camera gear for US bound flights - any experiences? SF1 Travel, Events, and Groups 4 03-05-2010 07:03 PM
Beach Camera experiences? Good or Bad? rdrum76 Photographic Technique 12 01-10-2008 11:06 AM
My London experiences(lots of pics) vdubbin099 Post Your Photos! 8 10-09-2007 11:25 AM
Unusual camera bags (+11 imgs) hinman Pentax Camera and Field Accessories 3 09-07-2007 06:10 PM
Henrys Camera Show (Lots of Pics) FotoPete Pentax SLR Lens Discussion 5 05-06-2007 08:09 PM
All times are GMT -7. The time now is 10:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
