04-27-2007, 01:26 AM   #1
For the studio guys with K10D....
How do you guys set the camera for focus. Manual or do you select the focus point in auto mode for every shot. I'm having my first shoot tomorrow and wnat to be efficient but yet get good results. Thanks.
04-27-2007, 01:53 AM   #2
Kim
Kim's Avatar
I'm propably not a "studio guy", but I've done a few studio shoots. I use AF and manually select the focus point. Works fine for me.
04-27-2007, 02:47 AM   #3
*isteve's Avatar
Yep - me too.
QuoteOriginally posted by Kim Quote
I use the K10D in the studio now and again and also use AF with manual point selection. So far very accurate and no problems.
Bear in mind that you really dont want to use a wide aperture in a studio situation unless you really want the shallow DOF effect for artistic reasons. F8 gives enough DOF on a 100mm lens at 3M (about 20cm) to keep the face and hair in focus but still defocus the backdrop. Use F1,8 and the DOF is down to around 2cm, which can look groovy but slight movement of you or the model can throw the leading eye OOF quite easily.
I normally set the lights for 1/125 at F10 on the incident light meter and set the camera manually. If I need to make a slight adjustment while shooting I will go F9 - F11 as required.
04-27-2007, 04:11 AM   #4
Got it. So when you choose your focus point for a headshot I suppose it's the eyes....but if it's a full length then where? I guess it diesn't matter a smuch people the lens is stopped down anyways? Am I understanding?
04-27-2007, 11:53 AM   #5
benjikan's Avatar
Phot Shoots in General
QuoteOriginally posted by sharpshoota Quote
I always use the auto focus function when using my camera. I always double confirm the focus before firing. In almost all cases it has worked well for me ever since using AF since 1988 or so.
Ben
04-27-2007, 11:28 PM   #6
stewart_photo's Avatar
Depends on what you're shooting. For product images, it can be either manual or auto depending on the item. For smaller objects, it is always manual due to the often narrow depth of field.
For people (which seems to be what you're interested in), it is auto focus unless situations force otherwise. For close-ups of people's faces, the "rule" is to always focus on the eyes. This is less rigid with full body shots because the depth of field is usually wide enough to keep everything in reasonable focus. I rarely worry about it in either case (close-ups or full-body), since depth of field is usually wide enough in either - in other words, auto focus usually does just fine.
Groups can be another matter. With larger groups, I have occasionally had to use either manual focus or selective AF to focus on the point I want. I avoid this by simply avoiding larger groups (haven't done one in years).
stewart
04-28-2007, 08:25 AM   #7
When shooting people in studio I am very pleased with the manual focus point selection in auto focus. Set the point closest to the subjects' eyes for minimal recomposing and let the camera do it's thing.
For macro I am a fan of manual focusing while using the optical depth of field preview to see the overall effect.
camera, dslr, focus, guys, photography
People How many guys can do this??! mr tibbs Post Your Photos! 11 06-28-2010 01:13 PM
Do you guys use this? LeDave Photographic Technique 4 07-26-2009 09:19 PM
Studio Flash Sync Speed for K10D fwbigd Pentax DSLR Discussion 3 01-01-2008 12:42 PM
Have you guys seen this? Tom M Pentax DSLR Discussion 0 12-05-2007 06:46 PM
Studio Flash for K10D benjikan Pentax DSLR Discussion 20 03-12-2007 08:04 AM
All times are GMT -7. The time now is 11:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
