06-18-2009, 04:36 AM   #16
Duck Dodgers's Avatar
Okay, that makes sense. There's no magic involved, it's just deferred.
06-18-2009, 07:05 AM   #17
QuoteOriginally posted by Duck Dodgers Quote
you may just call it deferred. but it makes lots of difference imo. for example, when taking shoots with fireworks, users can shoot with no wait between frame. Just hope pentax can implement this in the future.
06-18-2009, 02:13 PM   #18
Marc Sabatella's Avatar
I stand corrected. Quite clever, even if as was noted in the referenced thread, it doesn't actually work as well as doing it right away.
06-18-2009, 02:35 PM   #19
Are we still talking about dark frame subtraction? Does the 5D abort the dark frame, and continue later if interrupted or what?
06-21-2009, 05:35 AM   #20
Dark frame subtraction is not about hot pixels. It's about noise. True, PP programs can remove noise too, but the specific method use in dark frame subtraction is quite effective for the type of noise it removes, and it is *not* available in Pp (unless you happen to have an appropriate dark frame you can use, and the program supports it - most probably don't).
Noise is random and varies between shots. There's no way a dark frame can be used to reduce noise. Dark frames can only be used to detect hot pixels.
06-21-2009, 08:45 AM   #21
falconeye's Avatar
QuoteOriginally posted by patrickhh Quote
I studied long exposures with the K20D. As it turned out, there are a number of pixels in relatively constant locations which turn "dim" in long exposures. Still, too many and too variable to be mapped out. BTW, not specific for K20D. In my German forum, we even ran statistics between users and models to count their numbers below specific thresholds. Such dim pixels may escape to be detected as hot if they are not bright enough.
06-21-2009, 05:08 PM   #22
I guess that depends on what you mean by "hot pixels". There normal meaning of this is pixels that are permanently stuck on 100%. That's not what is going here, though - we're talking about pixels that simple read a bit brighter (or darker, I suppose) than they should. This comes out looking like noise, not like the "hot pixels" we normally associate with that term.
See:
Dark frame subtraction - Wikipedia, the free encyclopedia
camera, dslr, exposure, nr, photography, time, time exposure
K-7 Aurora long time exposure gives rings in the picture Mace Pentax DSLR Discussion 15 09-28-2010 06:14 AM
A long time exposure strange phenomenon current Pentax DSLR Discussion 7 06-08-2010 09:18 AM
How long will fresh batteries last in long exposure? tnis0612 Troubleshooting and Beginner Help 6 05-18-2010 09:11 AM
Long time lurker; 1st time post cmstringer Welcomes and Introductions 1 01-26-2009 02:16 AM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
All times are GMT -7. The time now is 11:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
