06-13-2009, 08:35 AM   #1
K20D Video Output
Hi there, I am trying to track down an answer from someone who possesses a mains power adaptor for this model
On a K20D can the Video Output lead be made to stay active (I.E. Continously feed a separate TV or monitor) if the camera is connected to a Mains power supply unit ?
When used on it's internal battery it does not appear to stay active for more than about five minutes, even if the timer menu is set to off ?
I don't realy need a Mains power supply, but I will happily buy one Just to obtain the special connecting lead
With this camera and it's (Catch-in focusing) arrangment, I belive it would make an ideal unit for local and backyard wildlife photography
I have asked many dealers and even pentax themselves, but It appears to be a question that they have not been programed for !
Any thoughts would be much apprecated
06-16-2009, 06:45 PM   #2
falconeye's Avatar
QuoteOriginally posted by Bodger Quote
Thought, not answer ...
I've it ringing in my ears that the timer in the K20D is disabled when you hook the camera up to PC, via its USB plug (even when on battery). Not sure if it must be open in Pentax Remote Assistant as well (guess not). It may be easy to fabricate a dummy USB plug which makes the camera believe that it is hooked up (I don't know).
As for external power: I don't believe that this disables standby. Again, not sure.
06-17-2009, 05:26 AM   #3
Hi there falconeye
Much obliged for your thoughts
Unfortunatly on this model both the computer (USB) lead and the Video output lead share the same socket, but not the same connections within the socket
Which does make life somewhat difficult !
Also there does not appear to be any way of getting a live video picture on to a computer screen via the USB socket, when you plug the USB lead into the camera, the live view instantly switches off
If I can't get the information that I am looking for, I know there is a work-around method, by fitting a four and a half minute timer into the remote control lead, this will take odd additional photos to ones I want, but it will keep the video output active
By the way If the camera battery goes flat while connected to a computer, the computer comes up with an error message, saying can't find camera ?
(The reason for asking this question origenally was because page 191 of the handbook, quotes, (If you intend to use the camera continuously for a long period, use the AC adapter, but it does not say wether all the settings will remain active)
Best regards Bodger
06-17-2009, 07:10 AM   #4
falconeye's Avatar
Oh well, you're right.
The K-7 has a separate (HDMI) video output (offering better quality as well (640x480)). But it goes mute as well if you connect to USB
Wouldn't the occasional shutter noise disturb wildlife?
06-17-2009, 07:54 AM   #5
Well you can't have everything ?
I figure a heap of cotton wool and a longer lens may help
But it's amazing how tolerant some wildlife is, you can very often see baby rabbits on motorway roundabouts, they don't seem to notice the forty tonners half a metre away
But must get back to some more bodging !!
Regards
camera, dslr, k20d, mains, output, photography, power, unit, video
Does K7 support HDMI output while recording video? johnmflores Video and Pentax HDSLRs 2 01-22-2010 08:04 PM
Question about K-X HD video output manteiv Pentax DSLR Discussion 9 12-10-2009 07:13 AM
K20D Video Output Bodger Troubleshooting and Beginner Help 0 06-13-2009 08:24 AM
K20D Video Output Bodger Troubleshooting and Beginner Help 2 06-02-2009 01:21 PM
The PENTAX Digital SLR Camera K10D's Video Output Format Timon@pentaxforums Pentax DSLR Discussion 21 09-20-2006 08:44 PM
All times are GMT -7. The time now is 11:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
