Originally posted by Class A
Not sure I agree a strong AA filter is a plus. Unless I'm missing something you can emulate a stronger AA filter with PP blurring but you cannot (quite) undo the blurring effect of a strong AA.
EDIT: The
difference between a standard Canon 5D and one with the AA filter removed (scroll down to see the after/before images side by side) is quite impressive; like that between an outstanding lens and an OK lens.
I'll check your link but an AA filter is a necessity until we get pixel counts high enough to not need them (that could be around a 50+mp range)... Sigma doesn't use one and many complain about jaggies.
It's a tradeoff and one to, I suppose, base your camera choice on. On one hand soft looking images, on the other jaggies and moire.
High quality lenses will usually give you the best results w/ even strong AA filters..
Marginal lenses, on the other hand, go to mush....
as frustrating as a strong AA filter, it is more frustrating to get moire patterns in textiles (and much harder to deal with)......
Why Pentax shifted from the weak AA (at least in 1 direction) on the k10 is unknown but some pre-production images had some terrible moire in some blue jeans and other images had it in different things as well.
EDIT: checking the Nikon photo the hot-rodded one shows moire everywhere (stop sign, AC on truck, AC on wall) and some of the detail, I suspect, is just artifacts from conversion, not true detail.
Best case would be a removeable AA filter so we can choose (ala Kodak back "in the day")
Screen capture added some artifacts as well as the now second conversion to jpg but there is plenty of detail and no moire and little "stepping", at least none objectionable:
AT 200X
