06-16-2009, 11:15 AM   #1
battery grip causing K20 problem
The problem began a while ago but I could not pin-point the source. The rear wheel on my k20 would stop working. At first my solution was to take all the batteries out (which involved taking the BG-2 off) and then putting everything back together and then things would work fine.
Now, however, the rear wheel will not work at all if the BG-2 is attached to the camera. Has anyone else encountered this?
Thanks... Chris
06-16-2009, 11:29 AM   #2
blende8's Avatar
This happens when a dial on the grip is between two positions.
Just turn the dials on the grip back and forth.
It should work then again, I hope.
06-16-2009, 12:16 PM   #3
Nowhere Matt's Avatar
Are you stating that the rear wheel of the camera body will not function when a battery grip is connected? That would be strange.
I have had instances where I was certain that exposures were incorrect because of not properly connected grip but for the rear e-dial doo hickie to malfunction does seem odd. Just as possible; but odd nonetheless.
And again I add nothing to the thread but an increase in traffic. So there ya go.
06-16-2009, 01:37 PM   #4
imtheguy's Avatar
No, thats not the case. He is referring to a known issue whereby if a wheel on the grip is only PARTIALLY turned and is BETWEEN click positions, that will affect or disable the camera body wheel. Simply check the grip wheels to make sure they did not catch on your sleve and get rotated slightly. It should not be something that happens everyday. My grip has not come off in 2 weeks and i use the camera every day but have yet to encounter the dreaded partial-click problem.
06-16-2009, 01:42 PM   #5
Jodokast96's Avatar
Also, check the electrical contacts between the grip and the body. One pin should be slightly shorter than the rest, but if there is more than one, that could be the problem. Also check that they depress and return freely.
06-16-2009, 02:11 PM   #6
QuoteOriginally posted by blende8 Quote
tah dah... thanks man. That was exactly the problem.
06-16-2009, 09:16 PM   #7
allill's Avatar
QuoteOriginally posted by kunik Quote
The half click thing can get annoying with the bg2.
06-16-2009, 09:21 PM   #8
imtheguy's Avatar
Is it a Pentax or a knock-off brand? just wondering if all of them are susceptable.
06-16-2009, 11:19 PM   #9
digitalphil's Avatar
I had the front dial stop working...
What happened was some pins bent ever so slightly and that by placing the grip in my gadget bag or by attaching the grip, a couple of pins had remained in the depressed position. I had to carefully coax them out. All is fine...now you know.
battery grip, bg-2, camera, dslr, k20, photography, wheel
K20 and the Battery Grip kshapero Pentax DSLR Discussion 17 01-07-2009 05:32 AM
Third-party battery grip for K10/K20 deepbluish Pentax Camera and Field Accessories 5 07-14-2008 05:25 PM
AA Battery grip for k10 / k20 / k100 philmorley Pentax Camera and Field Accessories 3 07-14-2008 04:29 PM
Battery grip causing weird readings? Inspection Guy Pentax Camera and Field Accessories 3 02-02-2008 09:25 AM
All times are GMT -7. The time now is 10:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
