06-18-2009, 04:11 PM   #1
K10D startup problem
Hi! Iv got a problem i just cant fix. When I tried to start up my K10D today it just showed a battery-symbol in the small Lcd-screen. It wont react to any of the buttons, and Ive tried to charge the battery and to disconnect/connect the lens.
Do anyone know a solution? I really want to use it this weekend.
Best regards Henrik
06-18-2009, 07:55 PM   #2
fishy's Avatar
That can happen if the SD card door is open. Maybe a faulty micro switch?
(Just tried to start my K10D with door open, battery indicator comes on, goes off, then nothing. That happen to you too?)
06-18-2009, 08:00 PM   #3
QuoteOriginally posted by killernils Quote
Best regards Henrik
You need to try a known good battery in your K10D, not just charge the old. Even taking a volt meter to your old won't give you enough info and tell you if its good/bad, only charged/not-charged. It would not hurt to have a look at the contacts as well. I hope this is all you need, a new battery.
Good luck
06-19-2009, 01:53 AM   #4
when I flip the startup-switch, I only get a battery symbol,and it stays that way. But I charged the battery this night (Im in Sweden), and when I tried it today it started up just right for a moment, the AF worked and did move the lens.
Someone on an another forum guessed it could be a faulty cell in the battery, so I hope it is the battery...
camera, dslr, k10d, photography
K 5 - Sensor shake on startup Naim Khan Pentax DSLR Discussion 13 10-25-2010 11:59 PM
Startup procedure SylBer Pentax DSLR Discussion 5 10-20-2010 05:18 PM
Pentax K-x first image capture on every startup comes out black akqrate Pentax DSLR Discussion 8 04-13-2010 11:50 PM
The Startup cost of Shooting Film little laker Pentax Film SLR Discussion 9 03-28-2010 11:22 AM
K10D problem Darius4522 Pentax DSLR Discussion 47 02-16-2007 09:01 PM
All times are GMT -7. The time now is 02:41 PM. | See also: NikonForums.com, part of our network of photo forums!
