Originally posted by lunelson To elaborate, due to the way JPEG compression works, the more detail an image contains, the larger the resultant jpg will be. Since the K20D achieves 10mp resolution images by downsampling with a large sensor, the images have more details before compression than a 10mp file from the K10D.
Thanks. As a technical person this is both understood and appreciated. Thanks!
Originally posted by GerryL Was this an actual experience shooting till the card ran out or are you going by what the camera said was shots available when you inserted the memory card unused?
Predicted number of shots compared to the actual are different.
A little of both. yes I realized it was "predicted." The predication generally came truew within a small margin of error. Thanks!
s.s
