Originally posted by swhang I have the Sigma 70-300 (non APO), and it does the job for most of my shots of birds. However, I want a longer reach for an affordable price.
I've seen plenty of crazy zooms that go from 800mm to 2000mm, but these look very cheap and are by no-name companies.
What would be a good solution to get a 400 or 500 mm reach for less than $600? I would prefer that this combo have autofocus.
If what you want mainly is longer reach, and if you're on a tight budget, your best option might be to buy a Sigma-brand teleconverter to go with your Sigma lens. I'd recommend the
1.4x teleconverter rather than the 2x. A teleconverter is attached to the camera the way you attach a lens, then you attach the lens to the teleconverter. It basically magnifies what you're getting from the lens, so, for example, the field of vision you'd normally have with the lens extended to 300mm is now equivalent to the field of vision you'd get with a 420mm lens (300 x 1.4 = 420).
Note that Sigma cautions that you should use only Sigma teleconverters for Sigma lenses and vice versa. I have never used a Sigma teleconverter myself but I suppose this stipulation has something to do with the way the lens communicates with the camera. I'd personally follow their advice on this, if I were trying to extend a Sigma lens.
What's the downside of a teleconverter? The main downside is that you lose some light. A 1.4x teleconverter typically costs you about 1 stop, so for example, your lens at 300mm has a max aperture of f/5.6. If you use the Sigma 1.4x teleconverter, the max focal length becomes in effect 420mm, but the max APERTURE becomes, in effect, f/8 (one stop slower than f/5.6). A 2x teleconverter is slightly more expensive than the 1.4x and will cost you TWO stops: your max f/5.6 becomes, in effect, f/11. In other words, you pretty much need to be shooting in very bright sunlight for it to work.
I go back and forth with myself on whether teleconverters are worth the trouble. But the 1.4x isn't TOO expensive and perhaps you should give it a try.
Another inexpensive option is the Pentax 300 f/4 which you may find used if you look around. I tried one some time ago and didn't feel that the image quality was better than I got from my Tamron 70-300, and of course with the Tamron I could zoom, so I sent the Pentax 300 back.
Or, if you want better photos more than nominally greater focal length, you could sell your current lens and get the somewhat better APO version of the same lens from Sigma. Or you could get the Tamron 70-300, which is very similar and which many people feel is slightly better than the Sigma. I have owned 'em both (the Sigma APO and the Tamron). I didn't honestly notice any big difference between the two in image quality: I sold the Sigma mainly because I had several other Tamron lenses at the time and for a while I decided to go with Tamron. But I was a little less picky two years ago when I owned the Sigma than I am today, so I guess you might look at the reviews. If I need to go long right now, I use the Tamron + a 1.4x Tamron teleconverter.
Remember, you should not be thinking just about focal length. A lousy lens that goes to 500mm is going to produce much less satisfying photos than a good-very-good lens that goes to 300mm, used on a camera like the Pentax K20D. A nice sharp capture at 300mm, taken with a camera with high-res, may be able to be cropped very nicely so that you end up with a photo result that looks like it was taken at 600mm.
In fact, forget 300: you might get better pictures by going SHORTER, down to the new Sigma 18-250 HSM, which has in-lens shake reduction for your Pentax camera. Yeah, paying for in-lens shake reduction kind of defeats one of the main points of the Pentax system, but in-lens SR is supposed to be slightly better, and I'd be willing to bet that this 18-250 HSM, properly used, would equal or exceed the image quality of your current Sigma 70-300. Anyway, keep in mind the basic truth of GIGO: Garbage in, garbage out. If the lens sucks, the fact that it has lots of reach isn't going to help you much.
Beyond that, this subject gets complicated. The short version is there are no telephoto zoom lenses for Pentax that have focal lengths greater than 300mm, excellent image quality AND a price under, oh, $700.
The cheap lenses you've seen for a couple hundred bucks (or less) from off-brand makes like Opteka or Phoenix are mirror lenses. You can read up on 'em, if you're interested. I've never used one. My understanding is that they CAN be okay, but they tend to have a lot of vignetting (in other words, they may be sharp in the middle of the photo but not at the edges).
Sigma makes a number of good-to-excellent long lenses, including the famous 50-500 "Bigma", but they're not cheap. The Bigma costs over $1000 right now at B&H Photo. In addition, it's BIG, hence the nickname. This means that it's a lot to carry out into the field if, say, you're a nature photographer. And at 500mm, well, you're really going to have to worry about camera shake. I've heard of people taking excellent photos at 500mm with a Pentax camera, hand held. But it's hard, and I'd imagine holding the camera with that huge lens on it would be really difficult. You're probably going to want a tripod.
If you have a few thousand dollars to spend, you have more options. :-)
Will
