06-23-2009, 03:49 PM   #1
When Shooting a manual lens with tele extender and SR on
do you set for the focal length of the lens or the lens with the extender on.
Example:
300mm lens with 1.4 extender is 420mm. Do you set for 400mm or 300mm ?
wll
06-23-2009, 04:27 PM   #2
You want to set SR to the actual focal length, or as close to the actual focal length as possible. So in this case, set for 400mm.
06-23-2009, 10:01 PM   #3
imtheguy's Avatar
If I may add a related question since this thread just reminded me....what about setting for a zoom? I have a manual 75-250mm. The answer is either the min, max, or avg I have to believe. Thats too many choices for a guess.
06-23-2009, 11:41 PM   #4
Steelski's Avatar
QuoteOriginally posted by imtheguy Quote
Someone actually said this a while back. I do not remember when or where, but it was from an official person....ish..
For a zoom, set it to the minimal, because you will still get SR effect, just not as aggressively.
06-24-2009, 02:51 AM   #5
K100D manual states that when using a zoom lens, select the actual focal length at the zoom setting.
So each time you change the zoom setting, you should change the SR focal length.
Don't know if that applies to other models, but don't see any reason it wouldn't.
06-24-2009, 06:08 AM   #6
imtheguy's Avatar
uh....right. I think I change the zoom far too often under normal circumstanstances to do that but I understand the official stance. Thats why I thought an Avg would work but maybe Min works because if it is overstated it causes a problem. I do know from experience if the setting is MUCH HIGHER than it should be it will make getting a clean shot harder than no SR.
Wll - I hope this is interesting to you otherwise sorry for jumping your thread.
06-24-2009, 06:15 AM   #7
wll
Quite all right as I use zooms also. So on a zoom maybe a midway set would be the best compromise unless you are using it at full length and reset it for that ?
wll
06-24-2009, 06:53 AM   #8
imtheguy's Avatar
QuoteOriginally posted by wll Quote
wll
Steelski [above] is quoting a previous source that we should use the Min instead of the midway. It makes some sense as I have tried to use SR with the number set far too large and it was impossible to get a jitter free shot.
06-24-2009, 09:38 AM   #9
GerryL's Avatar
I had this problem too with manual zooms.
I think the minimum setting is quite acceptable not unless you have a manual zoom that ranges from 28-300mm.
I believe for longer zooms, a bit closer to the negative median is my guess.
06-24-2009, 09:41 AM   #10
wll
Hay guys,
Thanks for the info, very helpful
wll
06-24-2009, 09:56 AM   #11
QuoteOriginally posted by GerryL Quote
I have a couple of manual zooms, and I've found the best response is by setting the focal length close to minimal. For instance, on my 70-210 I set it to 100 or 120 depending on light (120 low light, 100 normal/sun). Same with my 35-105 (70 low light, 50 normal/sun)
NaCl(I haven't had any problems with setting too high yet)H2O
300mm, camera, dslr, extender, lens, photography, tele extender
Auto tele converter to manual lens? COULDBE2 Pentax SLR Lens Discussion 5 08-11-2010 03:28 PM
Manual tele-lens choices over 300mm hinman Pentax SLR Lens Discussion 41 05-07-2009 01:54 PM
manual focus tele zoom jkglogau Pentax SLR Lens Discussion 7 03-06-2009 09:02 AM
shooting in manual SA Photo Troubleshooting and Beginner Help 38 02-03-2009 06:04 AM
where's the tele extender topic janosh Pentax SLR Lens Discussion 17 09-19-2008 01:46 PM
All times are GMT -7. The time now is 02:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
