12-13-2009, 01:41 AM   #256
jgredline's Avatar
K20D with the DA*50-135F/2.8, ISO 1600
12-13-2009, 01:49 AM   #257
jgredline's Avatar
Pentax K20D with DA*50-135F/2.8 ISO 3200
12-14-2009, 05:55 AM   #258
Christopher M.W.T's Avatar
f2.8 40mm @ 3200iso.
Really really poor lighting conditions.
Show in raw and just basic NR in ACR.
12-14-2009, 06:19 AM   #259
dadipentak's Avatar
That last shot of Daniel is great, Javier!
12-14-2009, 11:39 PM   #260
johnmflores's Avatar
Taken with Pentax K-x with DA 18-55 F3.5-5.6 ALII kit lens @35mm.
ISO 6400
F 5.6
1/8s
imported into Lightroom as a RAW and exported without any adjustments
12-15-2009, 01:05 AM   #261
Pentaxor's Avatar
Pentax K-7 + 55-300 , ISO 3200
out of camera jpegs. "pulled" exposure and resized.
1st photo: Completely NO Camera/PP NR used.
2nd photo: applied film grain NR.
PENTAX K-7  Photo
PENTAX K-7  Photo
12-15-2009, 04:38 AM   #262
dadipentak's Avatar
DC Metro
K20D & Sigma 24mm f/2.8: f/3.5, ISO 5000, 1/60s. minor tweaks, no NR.
PENTAX K20D  Photo
12-15-2009, 06:51 AM   #263
pcarfan's Avatar
QuoteOriginally posted by Pentaxor Quote
Pentaxor, are you sure that first shots was at iso3200 with no NR ?, was the jpeg set for high NR ?, even then that is very impressive. I cannot achieve those results without noise reduction, and thus my question. Actually with straight camera jpeg I may not be able to get that clean even at iso 1600 in that setting.
What is the shutter and aperture for that shot?
12-15-2009, 07:34 AM   #264
Amazingly clean have you got EXIF data?
12-15-2009, 08:06 AM   #265
reeftool's Avatar
These shots I took on Saturday at a Jr. high basketball game where my granddaughter was cheerleading. All at ISO 1600 which is all the K10D will do. The noise isn't bad and I find the high ISO shots from this camera as good or better than any high ISO film results I ever had. Not much PP, just a little cropping to remove unwanted stuff around the edges common to bleachers shots.
12-15-2009, 01:20 PM   #266
RuiC's Avatar
QuoteOriginally posted by Duck Dodgers Quote
Yeah, but that's some horrendous purple fringe on the subject's forehead!
That's not PF. It's pure stage lighting. It's normal.
Rui
12-15-2009, 01:47 PM   #267
Pentaxor's Avatar
QuoteOriginally posted by pcarfan Quote
Yes, the first jpeg photo was shot at ISO3200 with no NR. I completely disabled all the NR features on the K-7. the only thing that I did was to intentionally overexpose the image then later pulled it down. the idea was to retain as much detail, this would be impossible with NR on since it will blotch up the image or remove some of the minute details of the image. note that this is not a post-processed RAW file.
I only applied a bit of an off-camera NR (film grain type NR) on the 2nd jpeg photo afterwards just as a means of comparison for the 1st photo. the second photo still show a very nice and quite considerable detailed result but doesn't appeal to me as much as the 1st photo. for me, the second photo is just too amazingly clean even with a film grain effect. I prefer the quite dirty look feel of the first one. it gives more emphasis on detail.
shutterspeed is set at 1/160, aperture set at f8.
what really impressed me is the 55-300 lens that I used. I shot this photo at 300mm (450mm equiv.). and you can just see how really good this lens can be. I didn't do any sharpening of any sort btw on and off-camera. sharpness was set to -1. so this might have some effect on the noise output on the jpeg results making them much more tolerable and easier to deal with.
12-15-2009, 02:19 PM   #268
Pentaxor's Avatar
QuoteOriginally posted by C.W Tsorotes Quote
here you go,
Exif Sub IFD
* Exposure Time (1 / Shutter Speed) = 1/160 second ===> 0.00625 second
* Lens F-Number / F-Stop = 80/10 ===> /8
* Exposure Program = manual control (1)
* ISO Speed Ratings = 3200
* Exif Version = 0221
* Original Date/Time = 2009:11:08 22:47:48
* Digitization Date/Time = 2009:11:08 22:47:48
* Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
* Exposure Bias (EV) = 10/10 ===> 1
* Metering Mode = pattern / multi-segment (5)
* Flash = Flash did not fire, compulsory flash mode
* Focal Length = 30000/100 mm ===> 300 mm
# Last Modified Subsecond Time = 937
# FlashPix Version = 0100
# Colour Space = 65535
# Image Width = 800 pixels
# Image Height = 533 pixels
# Image Sensing Method = one-chip color area sensor (2)
# Image Source = digital still camera (DSC)
# Scene Type = directly photographed image
# Custom Rendered = normal process (0)
# Exposure Mode = manual exposure (1)
# White Balance = auto (0)
# Focal Length in 35mm Film = 450
# Scene Capture Type = standard (0)
# Contrast = normal (0)
# Saturation = normal (0)
# Sharpness = soft (1)
# Subject Distance Range = distant view (3)
12-15-2009, 02:29 PM   #269
Some thoughts after looking at all posts in this thread. It is obvious that both the K-7 and K20d can be used with no problems up to ISO 1100 and they're still very good at 1600. At ISO 3200 the results are more inconsistent. The K-X seems to be approx 0,5 to 1 stop better.
12-15-2009, 02:41 PM   #270
Pentaxor's Avatar
QuoteOriginally posted by Recercare Quote
I believe that's the idea. achieving good to very good images at ISO 3200 on the K20D/K-7 can be quite tricky. sometimes, some people can get frustrated. but if you nail it, the rewards are great.
camera, dolphin, dslr, flickr, gallery, iso, photography, post
How to post high resolution photo here? Underbridge Pentax Medium Format 5 12-25-2012 08:56 PM
People K-5 high ISO... how high can we really go... igor Post Your Photos! 2 03-24-2012 01:10 AM
Is there a high iso gallery for K-7? justtakingpics Pentax DSLR Discussion 13 05-31-2010 05:32 PM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
Pentax k20d High ISO Photo Gallery PentaxPoke Pentax DSLR Discussion 68 02-18-2009 05:19 AM
All times are GMT -7. The time now is 06:20 PM. | See also: NikonForums.com, part of our network of photo forums!
