03-30-2010, 06:15 PM   #436
mxguy's Avatar
Two ISO1600 hand held shots. I love SR.
K100D, M135/3.5 @ 1/20s, f3.5. ISO 1600
K100D, M135/3.5 @ 1/60s, f3.5. ISO 1600
03-31-2010, 12:28 AM   #437
JohnBee's Avatar
K20D ISO6400 images...
Using my own noise processing method, I decided to give LR3 Beta a try with some K20D ISO6400 images I had lying around. Here some some early results(5-15 mins. of PP ea.):
First candidate under inadequate florescent lighting:
Crop:
Second candidate under infrared heater lighting:
Crop:
Third candidate very low lighting(IR heater cast):
Crop:
Conclusion... with results like these... imagine what we could get out of Kx!!!
03-31-2010, 01:14 AM   #438
Pentaxor's Avatar
pretty impressive PP-NR work there JB. I still have to shoot above ISO 400 more often though. so a K20D and K-7 would be more than enough, unless I shoot under pitch-black, with no tripod and faster shutter speed for freezing motion (night action photo). but I think that would only be possible in a camera with a 25,600 ISO and higher. but as far as night shots are concerned, they are most likely done with a tripod and a flash.
the LR3 Beta does have an awesome NR tool. it does appear to remove unwanted noise effectively without the expense of losing detail and sharpness. and even able to enhance IQ further.
03-31-2010, 08:41 AM   #439
JohnBee's Avatar
QuoteOriginally posted by Pentaxor Quote
Thanks!
I should also mention that I used the following tools in processing these images.
1. GordonB's RAW Border Correcter
2. LR3-B2
3. Photoshop CS4
5. Niksoft Dfine
The rest is a culmination of creating seperate working layers and masking in select areas into a final composite. Which is much easier than it sounds.
04-03-2010, 09:59 AM   #440
Jewelltrail's Avatar
JohnBee: I should also mention that I used the following tools in processing these images.
2. LR3-B2
3. Photoshop CS4
5. Niksoft Dfine
John, thank you for this very nice work.
04-03-2010, 10:10 AM   #441
ISO 1600
04-04-2010, 05:59 PM   #442
kristoffon's Avatar
ISO 1600
f/11
1/350s
K20D & Vivitar 100mm macro
jpeg straight out of camera
click for bigger
04-04-2010, 07:33 PM   #443
Nice shot with lots of detail. I downloaded the largest size @ Flicker & strained my eyes looking for noise. That is ETTR in effect
04-04-2010, 08:04 PM   #444
kristoffon's Avatar
QuoteOriginally posted by Jewelltrail Quote
Thanks!
And of course in this low resolution noise does get smoothed out a bit too...
04-04-2010, 11:00 PM   #445
Perrumpo's Avatar
Nothing spectacular, but I just decided to play around with taking some pictures of my cat tonight in my very-poorly-lit room at a high ISO. No PP.
ISO 3200
f/1.4
50mm f/1.4 M42
K-x
04-05-2010, 09:08 AM   #446
Marc Sabatella's Avatar
This shot from last night surprised me in that there was no direct light on the subject at all, and not only was I shooting my K200D over 1.5 two stops underexposed at ISO 1600 (for the equivalent of around ISO 4500 or a little higher), but even then I was shooting at 1/15" just to get there. I really didn't expect to have anything usable at all. So I was quite happy to get this:
[IMGTALL]http://marcsabatella.zenfolio.com/img/v0/p579072360-6.jpg[/IMGTALL]
K200D, DA70, f/2.4, 1/15", ISO 1600 pushed to 4500
04-05-2010, 10:59 AM   #447
Pentaxor's Avatar
nicely done Marc. that photo somehow poses the argument of "who needs High ISO?" while you can post-process by using ETTR/ETTL methods and great NR tools (JB makes some really impressive NR work).
High ISO is mostly limited or somehow needed in situations that require it such as freezing the action or in a mad rush taking candid pictures at really low light situations. it's a matter of how often you shoot that kind of photography. but as most night or lowlight photography is concerned, a tripod or use of a flash or other lighting equipment has always been the best way of getting optimal results.
04-05-2010, 12:42 PM   #448
Marc Sabatella: This shot from last night surprised me in that there was no direct light on the subject at all, and not only was I shooting my K200D over 1.5 two stops underexposed at ISO 1600 (for the equivalent of around ISO 4500 or a little higher), but even then I was shooting at 1/15" just to get there. I really didn't expect to have anything usable at all. So I was quite happy to get this:
Amazing indeed! The blur which is present @ 1/15th only highlights the magic of the shot: we can intimate the sound of music from the blur on the fingers of his right hand--splendid.
04-06-2010, 01:37 AM   #449
This shot from last night surprised me...
Do you have the full size pic somewhere on the net? I wonder how it looks in pixel-peeping mode
04-06-2010, 01:48 AM   #450
ar9
k-x
iso2500
da70
PENTAX K-x  Photo
camera, dolphin, dslr, flickr, gallery, iso, photography, post
How to post high resolution photo here? Underbridge Pentax Medium Format 5 12-25-2012 08:56 PM
People K-5 high ISO... how high can we really go... igor Post Your Photos! 2 03-24-2012 01:10 AM
Is there a high iso gallery for K-7? justtakingpics Pentax DSLR Discussion 13 05-31-2010 05:32 PM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
Pentax k20d High ISO Photo Gallery PentaxPoke Pentax DSLR Discussion 68 02-18-2009 05:19 AM
All times are GMT -7. The time now is 01:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
