07-02-2009, 08:38 PM - 1 Like   #46
FotoPete's Avatar
Pentax K20D w/ Jupiter-9 85/2
Shot at ISO 1600, f2, 1/180s.
Its a marvel how friendly these birds are!
07-03-2009, 06:49 AM   #47
What about this set:
shot with my Vivitar 105 Series 1
07-03-2009, 11:29 AM   #48
Jewelltrail's Avatar
There is so much excellent work here! Norris Tudor, great detail in that crawler at all ISOs.
07-03-2009, 07:47 PM   #49
Rupert's Avatar
!SO 6400 Raccoon...
I have a lot of these, this is one of my favorites. K20D+DA*50-135 @135mm F2.8 ISO6400...Light from a nearby floodlight. !/30 Handheld.
07-03-2009, 07:48 PM   #50
Rupert's Avatar
!SO 6400 Raccoon...
I have no idea why the iage is not showing....?
http://www.pbase.com/rupertdog/image/102467852
07-03-2009, 10:05 PM   #51
Raybo's Avatar
QuoteOriginally posted by Rupert Quote
IMGP7846-800.jpg photo - James Williams photos at pbase.com
You have the best images as of yet Rupert!
Ray
PS NOT!
07-04-2009, 01:09 AM   #52
Igilligan
Guest
K20d ISO 6400
Since I just posted my favorite ISO 1600 shot from the K100d
I thought I would post a ISO 6400 shot from the K20
K20d - ISO 6400 - with the M50 F4 macro - Jpeg
That right ISO 6400 jpeg no extra nr in pp
p.s. B&W is your friend
07-04-2009, 04:44 AM   #53
There are some GREAT examples in this thread which show a new guy like me how excellent the shots at high ISO are with the Pentax bodies. I just today got around to some numpty shots at 3200...just took this one in a dark corner of a BIG room in the shadows. It is nothing special I know, but to me it gives me the confidence to actually use high ISO on the 20D. The key is I did not do any noise reduction. I only made a few adjustments to the levels...
K20D, FA 77mm Limited, f/1.8, 1/20, ISO3200 {click to view larger sizes}:
I suppose this is what one does with a wicked case of insomnia after a few months...
EDIT: Here is another I took. Again no NR, but there was a crop on this shot. Also, I intentionally made it a bit too contrasty that it should be just to see how I liked it...fun stuff!
K20D, FA 35mm Limited, f/2.8, 1/25, ISO3200 {click to view larger sizes}:
07-04-2009, 05:16 AM   #54
I think noise issues are only a problem when you underexpose...probably the same as any other camera!
07-04-2009, 05:44 AM   #55
ISO 1600 f5.6 40 sec Kit 18-55
07-04-2009, 08:53 AM   #56
Rupert's Avatar
ISO6400 Raccoon
K20D+ DA*50-135 ISO 6400 135mm F2.8 1/90 SR Lighting by nearby floodlight on my back porch. I have tons of these, and while not perfect, they beat missing the shot. If the K7 is as good or better, I will be well pleased!
Regards
Rupert
07-04-2009, 10:00 PM   #57
octavmandru's Avatar
Regards
Rupert
Did you PP?
K20D, Tamron 18-200, iso 1600
07-05-2009, 11:31 PM   #58
K20D at ISO 2500
Here are 3 versions of the same image, converted from raw using Capture One Version 4. I have no issues with the high performance of the K20D since I prefer keeping detail and microcontrast at the expense of some digital noise.
K20D; DA*50-135 @ f/2.8; 1/60 sec; ISO 2500
C4 conversion; default sharpening; no noise reduction
C4 conversion; Noise Ninja/Focal Blade
C4 conversion; no noise reduction/Focal Blade/Silver Efex Pro
07-06-2009, 03:51 AM   #59
QuoteOriginally posted by NorrisTudor Quote
Ture....mostly...but it's not 100% true all the time and in every situation. It also has to do with the sensor and the camera's ability to grab the data from the sensor and process it correctly. It's more technical then that, but proper exposure might not ensure no noise in a shot. I only learned it to that level because beyond that, my brain implodes...hehehehe....
07-06-2009, 11:17 AM   #60
ISO 1600, Handheld
K100D Super
DA 18-55
18mm Focal Length
1/6 sec
F3.5
Program AE Mode
Multi-Segment Metering
WB Auto
RAW, Converted directly to JPG via PhotoBrowser
ISO 1600
Resized to 800 pixels wide
No NR applied
camera, dolphin, dslr, flickr, gallery, iso, photography, post
How to post high resolution photo here? Underbridge Pentax Medium Format 5 12-25-2012 08:56 PM
People K-5 high ISO... how high can we really go... igor Post Your Photos! 2 03-24-2012 01:10 AM
Is there a high iso gallery for K-7? justtakingpics Pentax DSLR Discussion 13 05-31-2010 05:32 PM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
Pentax k20d High ISO Photo Gallery PentaxPoke Pentax DSLR Discussion 68 02-18-2009 05:19 AM
All times are GMT -7. The time now is 09:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
