07-27-2011, 06:35 PM   #976
QuoteOriginally posted by johnmflores Quote
Much better. Just one problem remains - his trumpet's too small!
yeah....
but do you how BIG the guy is?
Thanks very much for the help.
07-27-2011, 06:44 PM   #977
Pentaxor's Avatar
Thanks for the advice - feathered sounds theoretically better but from my experience with defined shadows like that photo, does not work - then even I can see it on my monitor - like I said I have an "olde fashioned" CRT monitor - those are hard to beat - more modest/cheaper LCD monitors can cause problems, it's not the resolution that everyone looks at - but the gamut display and contrast - often what suits text does not suit photos - I know my friend's Mac monitor is premium - but it is way out of whack - however it is useful for me to check for problems like that photo -
Like I asked are there others that see what you saw? -
if it's the majority then I'd switch monitors -
This photo is a good case as the adjustment was quite extreme - like I said I cannot see it on my monitor.
Thanks for the input - very grateful for it.
EDIT to ADD - just saw this:
Thank you - that does it - I'll reprocess the photo and replace the photo posted -
would really appreciate if you can please comment on it to see if the processing is obvious.
Thanks.
I can see it clearly as well. I'm not using a MacBook though, so it has to be your monitor.
07-27-2011, 07:32 PM   #978
QuoteOriginally posted by Pentaxor Quote
Thank you -
you mean earlier (before about 6pm EDT, Jul/27) when the problem was first noted -
or do you mean you can still see it now?
If so, would you mind please let me know the url of the photo?
Thanks
07-27-2011, 10:30 PM   #979
Pentaxor's Avatar
Thank you -
Thanks
the first one.
07-28-2011, 10:59 AM   #980
the first one.
Cool! thank you.
It is obviously my olde CRT monitor -
which BTW does display photos really well -
BUT obviously cannot see the issues that we just had -
I'll post the culprit photo again here -
The shadowed part of the face would appear as if has a lightened mask on it -
it was from my post-processing - select area and brighten to show more detail -
but obviously I cannot see the the problem on my CRT monitor, that I think high contrast LCD screen can.
Just out of interest are there any with LCD monitors who do NOT see that problem even when highlighted please?
Thanks for the input on this - I am very grateful.
07-29-2011, 05:34 PM   #981
from last night:
ISO5000, f/4.5, 1/13; 68mm; -2/3 stop comp
light in center of stage virtually nothing else.......
Even stronger pic -
ISO5000, f/4, 1/60; 31mm; -2/3 stop comp
light colored shirt made all the difference - but this high contrast shot is just because there was only light in center of stage.......
ISO5000, f/4.5, 1/50, 73mm; -1 stop comp
No I haven't gone soft .... and shot only in the light.......
ISO5000, f/4, 1/13; 24mm; -2/3 stop comp
shot was underexposed probably due to the candles in the picture.....
but it turned out sharper than I had any right to expect.......
ISO5000, f/4.5, 1/10; 43mm; 0 stop comp
below main subject in silhouette due to the stronger light (night street) through the window - I deliberately left the out of balance bright part on the bottom right - that is reflection off the floor from the street lighting through the window......
I think those are pretty hardcore dark......
07-31-2011, 02:45 AM   #982
3 shots
1. Frank Lloyd Wright house in Two Rivers, WI
2. Spaceship Earth at Epcot in Florida
3. Brothers wedding, late afternoon under a pavilion
Check exif data for details. No noise reduction
PENTAX K-7  Photo
PENTAX K-7  Photo
PENTAX K20D  Photo
07-31-2011, 07:20 AM   #983
Not the best subject but shows ISO 6400 performance. No PP. Noise reduction set to [Auto]. Shot in .jpeg
07-31-2011, 01:43 PM   #984
melvis2's Avatar
High ISO
I have no idea why I like this photo but for some reason I do. I was playing with the camera when my son walked by and I snapped this one. f/5.6 @ ISO 5100
07-31-2011, 01:45 PM   #985
melvis2's Avatar
Sorry meant to read ISO 51200. That makes better sense huh?
08-01-2011, 05:58 PM   #986
K20D + Kit Lens 18-55 (x-posted)
Expanded ISO 6400 > JPEG > Faststone and Corel NR, relatively surprised by results, which could have been improved with a little more PP time but...
Details
08-03-2011, 04:33 AM   #987
richard balonglong's Avatar
"On the Side"
Camera: Pentax K-7
Lens: Ricoh 28mm f/2.8
ISO: 6400
Shutter Speed: 1/10 sec.
Aperture: f2.8
Mode: Manual
Format: DNG
08-03-2011, 10:06 AM   #988
Moderately high ISO.
K-x, ISO 4000, 1/25, f5.6, 55mm, 18-55 DAL II kit lens, hand-held, shake reduction on. No PP.
08-03-2011, 10:55 AM   #989
NICE! rawr -
good eye - good sense of composition -
it's such a good photo that it really would not have mattered even if it were "noisy"
- but the low noise of the K-x makes a real bonus.
08-03-2011, 11:10 AM   #990
Thanks!
But in looking at it again I should probably have cropped in by 5-10%, and shopped out that white pole in the middle of the roof. Maybe I'll do that if I ever print it out.
camera, dolphin, dslr, flickr, gallery, iso, photography, post
How to post high resolution photo here? Underbridge Pentax Medium Format 5 12-25-2012 08:56 PM
People K-5 high ISO... how high can we really go... igor Post Your Photos! 2 03-24-2012 01:10 AM
Is there a high iso gallery for K-7? justtakingpics Pentax DSLR Discussion 13 05-31-2010 05:32 PM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
Pentax k20d High ISO Photo Gallery PentaxPoke Pentax DSLR Discussion 68 02-18-2009 05:19 AM
All times are GMT -7. The time now is 06:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
