11-28-2011, 11:14 PM   #1036
There are other things that come into play too (for a different discussion). White balance is far better on the KX than on the K200D and K20. This adds to the KX, and newer, having quicker workflow. That just comes with newer technology.
Shooting in RAW with the has made a world of difference for my photography. It gives me so much more room to work. Further, blackening the blacks works well too.
K200D @ 1600
11-29-2011, 10:24 AM   #1037
VisualDarkness's Avatar
QuoteOriginally posted by audiobomber Quote
DXOMark allows you to compare raw performance: low-light ISO is the highest ISO setting for a camera that allows it to achieve an SNR of 30dB while keeping a good dynamic range of 9 EVs and a color depth of 18bits.
A difference in low-light ISO of 25% represents 1/3 EV and is only slightly noticeable.
K20D = ISO 639
K-x = IS0 811
K-5 = ISO 1162
Wow, K-7 was bad at 536 and an overall at 61.
11-29-2011, 12:27 PM   #1038
K-7 isn't bad, people just can't take pictures anymore unless the camera does everything for them
11-29-2011, 12:29 PM   #1039
QuoteOriginally posted by Macario Quote
True, like me.
11-29-2011, 01:28 PM   #1040
SMPhoto's Avatar
Still impressed by the results I get with my K20D at ISO1600. I actually tend to find that I prefer the look of ISO1600 more than 800, for some reason.
Here are a couple shots at ISO1600 of a Hammered Dulcimer which was put on display at a Celtic festival I went to.
Lens was Sigma EX DG 24-60mm f/2.8, 1/15s at f/4.5 on both.
No NR applied.
100% crop of shot #1:
11-29-2011, 01:46 PM   #1041
QuoteOriginally posted by VisualDarkness Quote
I can't truly tell the difference between the K7 and K20 (Difference between iso 630 and 530 is not visible as someone else mentioned). One thing to mention is that the K20 had obligatory noise reduction that started at iso 1600, whereas, the K7 allows you to turn off noise reduction up to iso 3200.
11-29-2011, 02:19 PM   #1042
audiobomber's Avatar
If that were true, the ISO 1600 dot on the DXOMark SNR graph would be hollow, and it is not. Both are shown to have undefeatable NR at ISO 3200 (same for the K-x, K-r and K-5). The K200D has NR starting at ISO 800.
11-29-2011, 03:04 PM   #1043
QuoteOriginally posted by SMPhoto Quote
No NR applied.
Wow! I've found another K20 shooter that likes ISO1600 and I agree as well with your 1600 v. 800, the colors seem to be much richer. In fact I usually either shoot at 100 OR 1600 and haven't found a sweet spot in between; at least not yet. I would probably use 1600 for everything, but I'd need to get a set of ND filters...
@ ISO1600 Pentax F 50/1.7 No PP just resize...
@ ISO1600 Tamron AF 28-80/3.5-5.6 Used Gimp filter G'MIC to smooth out...
11-29-2011, 03:50 PM   #1044
Keep'em coming. Love to see the photos. I have that Sigma 24-60mm and I like it.
11-29-2011, 05:36 PM   #1045
SMPhoto's Avatar
QuoteOriginally posted by theunartist Quote
That's interesting. I just seem to find the grain much smoother and less evident in general at ISO1600 vs 800 - this also applies to long exposures, for me. ISO200 is my default setting for most daytime shots, I actually can't find any discernible IQ difference between that and 100 most of the time.
Thanks for sharing the shots!
QuoteOriginally posted by john5100 Quote
Thanks John, the Sigma really is an incredibly versatile lens and a great value.
11-30-2011, 06:31 AM   #1046
Designosophy's Avatar
One of the interesting things about the K-5 is that noise starts creeping in at fairly low ISOs, and it's possible to bring out noise with sharpening even at ISO 80. With the K-x, at ISO 100, I couldn't bring out noise if I tried, unless I underexposed significantly, then pushed the exposure in post.
11-30-2011, 07:06 AM   #1047
JohnBee's Avatar
QuoteOriginally posted by Designosophy Quote
aside from some slight variances in sensitivity between both camera's, I've found that they are inherently the same. However.. the K-5 RAW files seem to have slightly more color saturation than the K-x which I believe contributes to the appearance of chroma noise earlier than with the K-x files. However, I've found that this usually doesn't present any problems when using RAW developers that offer noise control features such as with Raw Therapee. Whereas developers such as Adobe Camera Raw and Light Room(for example) seem to degrade color detail with chroma control measures.
Having said that, while I'd agree that the K-5 can exhibit chroma noise at base ISO, I've also found that the phenomenon will vary based on exposure. ie. files that are well exposed seem to hold-up very well against even the most aggressive processing whereas files that lean toward underexposure will exhibit chroma noise quite easily.
12-02-2011, 04:50 PM   #1048
Kx + Kit Lens 18-55
@ ISO3200
(x posted)
12-03-2011, 01:50 AM   #1049
danielchtong's Avatar
This came way back from a lowly DL at 1600 in 2007 with FA135
Large file
IMGP8141.JPG photo - Daniel TONG photos at pbase.com
Daniel
12-03-2011, 04:36 AM   #1050
Kx + Kit Lens
@ ISO12800
camera, dolphin, dslr, flickr, gallery, iso, photography, post
How to post high resolution photo here? Underbridge Pentax Medium Format 5 12-25-2012 08:56 PM
People K-5 high ISO... how high can we really go... igor Post Your Photos! 2 03-24-2012 01:10 AM
Is there a high iso gallery for K-7? justtakingpics Pentax DSLR Discussion 13 05-31-2010 05:32 PM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
Pentax k20d High ISO Photo Gallery PentaxPoke Pentax DSLR Discussion 68 02-18-2009 05:19 AM
All times are GMT -7. The time now is 05:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
