Originally posted by GarySloman I shoot DNG. Maybe the problem is Lightroom. Does anyone have this problem who is not using Lightroom?
THanks, Gary, for weighing in here. It looks as if everybody who has had this problem was using Lightroom. To be honest, the thought that it is Lightroom's fault makes little sense to me as a programmer. Usually, I expect bugs to exhibit themselves consistently. If Lightroom can't read PEF files, I expect it to have problems every time. MIGHT be a memory management problem. Problem does seem to occur only when I'm importing lots of image files at once. And I convert them from PEF to DNG during import. But I would not expect a memory management problem to cause it to fail to import one or two images - I'd expect it to cause the import process to stop, or the program to crash, or something really bad like that. Instead, Lightroom actually handles the problem fairly gracefully, reporting at the end of the process that the following file(s) could not be imported, sometimes offering a reason for the failure, and listing the names of the files. Not prima facie buggy behavior. At the moment, I'm more inclined to suspect the card itself, the way I've formatted it, or the card reader.
But it seems I have a lot of theories to test.
1. Have reformatted SanDisk card and will use it exclusively for a few days. If problems go away entirely and never return, I'll conclude it was the formatting of the card. May consider henceforth using Format option to clear the card rather than using the "delete all" command in the camera.
2. Try a different card reader.
3. If I still have problems after 1 and 2, I'll switch to the Transcend card exclusively for a week, after reformatting it. If I have no problems, I'll suspect that it was the SanDisk card.
4. If both SanDisk and Transcend cards have problems, even after reformatting, I'll consider the possibility that the problem lies with Lightroom. Might change my import options NOT to convert to DNG at the time of import.
If I haven't solved the problem by step 4 in the testing process, I'll throw the K10D and the Dell laptop away and go back to my Nikon film camera. ;-)
Will
