06-27-2009, 01:01 PM   #1
Lowell Goudge's Avatar
K10D Mirror Slow to raise
Has anyone had the mirror fail ont he K10D?
Mine is slow to lift,
At 1/2000 only about 5% of the frame is exposed the rest is black,
as shutter speed is reduced more of the frame is exposed until by about 1/640 the entire frame is exposed properly.
Time to visit Pentax Canada.
06-27-2009, 02:39 PM   #2
Nope, tuff luck.
How many actuations has the camera done so far?
Could it be wearing out of the shutter mechanism?
- Bert
06-27-2009, 02:58 PM   #3
bert
only 12500 actuations, but owned since dec 2006 so definitely out of warranty
shutter is fine, this is definitely something in front of the shutter blocking the light, there is only 1 thing, the mirror.
can't be lens because it does the same with miltiple lenses and all the lenses work on my *istD
06-27-2009, 03:45 PM   #4
Duck Dodgers's Avatar
Works okay during MLU, then?
06-27-2009, 04:28 PM   #5
good idea on mirror lock up
made no difference, perhaps shutter after all
06-27-2009, 04:31 PM   #6
Yeah, sounds like a slow curtain.
06-27-2009, 04:46 PM   #7
Damn Brit
Guest
Have you checked the mirror to see if it has moved out of position slightly Lowell?
06-27-2009, 04:49 PM   #8
QuoteOriginally posted by Damn Brit Quote
mirror looks fine.
oh well, perhaps this is a message to get a K7
06-27-2009, 05:16 PM   #9
Damn Brit
Guest
mirror looks fine.
I foresee a couple of shiploads of cameras in the marketplace in the near future.
06-27-2009, 05:43 PM   #10
Were you using the flash?
06-27-2009, 06:15 PM   #11
QuoteOriginally posted by Old Timer 56 Quote
nope
was fooling around with my 85mm F1.4. and shalow DOF, even at ISO 100 you need high shutter speed, and I had notised a couple of shots yesterday that seemed dark in areas, but it was in consistent,. today it is quite consistent
06-27-2009, 06:17 PM   #12
I was thinking the same thing.
I think I will go for K7, I have been split between K20 and K7, for a while, wanting quality Higher ISO than the K10.
probably get the K10 fixed as a back up
06-28-2009, 02:28 AM   #13
Andi Lo's Avatar
These digital cameras actually have a curtain? I always thought it's the sensor directly behind that mirror...
06-28-2009, 06:04 AM   #14
I guess it is making room for your new K7...
06-28-2009, 02:39 PM   #15
pop4's Avatar
QuoteOriginally posted by Andi Lo Quote
Yes, dSLRs do. Most compacts don't, but then again, they don't have mirrors either.
The order from front to back goes lens, mirror, shutter (front and back curtains) and then sensor.
Here's a good link to see how it works: Jeffrey Friedl’s Blog Blog Archive Nikon D3 Shutter Release in Super Slow Motion
camera, dslr, frame, k10d, mirror, photography
K10D Mirror Jam winglik Pentax DSLR Discussion 3 03-27-2010 09:58 AM
Tamron 70-200mm f2.8 on K10D, how slow is AF? aquashin Pentax SLR Lens Discussion 1 02-24-2010 11:58 AM
Slow AF? Slow TTL? Check 'em batteries!!! jboyde Pentax DSLR Discussion 11 04-30-2009 06:41 PM
K10D: USB Transport modes; PC-F?? (Slow import in Lightroom) fishy Pentax DSLR Discussion 3 12-03-2007 04:45 PM
Slow K10D auto bracket ukbluetooth Pentax DSLR Discussion 4 11-24-2007 08:57 AM
All times are GMT -7. The time now is 01:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
