Originally posted by switch79 Hi all, I have downloaded the most recent firmware update for the K10D, as well as the one for the ist*DS. I was reading some previous posts about some problems with the update and the consequences as a result. Prior to installing these updates I was just curious to know wether or not you guys out there update the firmware regulary. I certainly cannot afford for something to go wrong and as a result be without my camera's for a while.
What is your experience with firmware updates? Are things going wrong as a result of not following instructions and/or are these isolated incidents?
Secondly, I have yet to do an update since I bought the camera in January so will 1.20 include everything that was in 1.10 & 1.11 or do i need to download each update in order to get all the fixes and adjustments.
Your feedback is appreciated,
switch79.
There are a small number of isolated failures with firmware updates--these will typically require a trip to the service shop.
Charge the batteries fully. Reformat a quality SD card in the camera then transfer the update to the card from your PC via a card reader or a cable--any method is fine. The file must be in the root directory.
Follow the instructions for starting the update; start the update and hold the camera quietly or set in down on a firm surface. Do not push any buttons beyond what the instructions specify. Relax, it takes a couple minutes, the card busy light will blink rapidly when it is done and the screen will have a confirmation message (this has been known to not appear in some models early in the production). Turn camera off, remove card, turn camera on and do the version check.
I've done it each time a new version has released for five different dSLRs--never a hitch!
