Originally posted by rawr I guess if one had the time you could try and induce a similar failure by putting a big fast SD card into the camera, charging up all your NiMh batteries in grip and body, and then just holding down the shutter button for 500-600 exposures (or whatever) and see if the problem can be made to recur.
And just keep on doing variations of that procedure (grip on/ grip off, SR on/ SR off, AF-S on/AFS-off, etc) until you find a combination of settings where you can consistently and repeatedly trigger the lockup.
May be time consuming though but it might be the only way to nail down the root cause of this and what the problem component or issue may be.
Another option may be to scour the web to see if there are other reports of similar K200D lockups, and then see what these reports have in common.
Last year I did a test to check for battery life and did over 1000 shots holding the shutter button, without problem. I only had a few 2GB cards and I had to change them, though. Now I have a 16 GB card.
But the shutter is supposed to have a limited life of about 100,000 clicks. So I don't think I would want to reduce the life of the camera by trying this again.
But if that will help anyone, when it occurred, I had SR ON. The whole day. I was on AF-S mostly, though a few times my fingers switched the camera to MF accidentally.
I used mostly the AUTO and NO FLASH shooting modes.
I didn't do much other than half presses for focus and full press for shoot. I had the very occasional picture review only with the play button and zoom with e-dial. But not before the problem occurred, as far as I remember.
