06-30-2009, 09:04 AM   #31
GoldenWreckedAngle's Avatar
QuoteOriginally posted by little laker Quote
I just tried the same technique with my Sigma SD14, along with a Flash Waves radio popper and it appears to be an interesting technique.
At 1/500 you can hardly make out the flash along the top of the frame.
Without the trigger I could only go up to 1/200, which in my opinion is still fine for most work.
I would think that your Pentax would act the same, with a radio popper.
Since I no longer own a Pentax I can't try it and find out.
I missed this post yesterday for some reason but this is one of my growing list of frustrations with the Pentax flash system. It doesn't act the same way, but it definitely needs to. I'm watching the Samsung news and rumors at the moment. There may be a K-mount solution in the near future, we'll see...
... but, it should have been the K-7 (grumble, grumble, mumble and kick the dog) I really need to just let it go and go shoot something that get's me fired up about my Pentax again. No point in hanging on the negative points of my gear, that never improves my images. The Pentax system is finicky in points, and downright stubborn when it comes to flash, but it can still make magic when you ask it nicely and embrace its strengths.
06-30-2009, 09:17 AM   #32
QuoteOriginally posted by kunik Quote
I made no mistakes. Sometime between taking pictures the flash had wiggled loose and the connections were apparently no longer lining up properly ...
I swear I'm going to strip my flash's hot shoe threads some day trying to crank that knurled knob down tightly enough to keep this from happening to me all too often. I keep toying with the idea of roughing up the top of my hot shoe with sandpaper a bit to give it a little better grip. The only thing that's kept me from it so far is the future e-bay listing that keeps popping into my head every time I use the Pentax flash system.
06-30-2009, 09:21 AM   #33
QuoteOriginally posted by GoldenWreckedAngle Quote
Since getting the 580exII for the Canon I have been thinking all flashes should have a flick-lock attachment like that. I absolutely love how secure it is. But then I started hearing from people that it was breaking a lot... I guess its tougher to build a good system than it would appear.
06-30-2009, 09:42 AM   #34
A few years ago I had the Kodak P880 Pro-sumer camera it had everything a dSLR has but no SLR or changing lens! Anyways it used a mechanical shutter, a leaf shutter and could sync with my P20 external flash at any speed. I did some strange things with that ability. I could take a pic in a room lit with an tungsten bulb at 1/4000 and completely eliminate any light coming from the bulb. Having the ability to hi-speed sync with a powerful external flash is something modern dSLRs are in need of and you don't loss any power at speeds > 1/2000, because most time the flash is a very fast burst of light. And BTW a hybrid (non-slr) camera could bring this ability back to us I believe becuse there would be room to bring the shutter up close to the rear element(?). There is so many advantages to hybrids its not funny. With only one loss, the OVF, and thats a big loss!
Just some fun snaps I did a couple years ago, all with the P20 external flash (about like the Pentax AF360) and Kodak P880 with leaf shutter that could work up to 1/4000 with the flash. I can't find the pics of me freezing things in mid-air, with a speed of 1/2000 you need a lot of light, but if your flash and camera can sync you can throw stuff and take a pic of it, very fun ,
both taken if I remember right at 1/2000 you can freeze the fastest moving subjects with ease!
Dark room lit with one bulb first taken at 1/60, second at over 1/1000 and nothing is lit by the bulb anymore only the flash is lighting the room at this capture speed.
06-30-2009, 10:05 AM   #35
I've been learning a bit about leaf shutters lately and they are certainly cool. If I were a little smarter I might try building one into an SLR lens and see what it could do.
06-30-2009, 01:54 PM   #36
krypticide's Avatar
Hm, I have my K20D set at rear curtain sync at all times, and I haven't had this 1/90th second limitation. I need to reconfirm this though.
06-30-2009, 02:17 PM   #37
bentax's Avatar
No, the moment you turn on the flash in rear curtain sync mode your shutter speed drops to 1/90, the "X" sync speed for that feature.
Hmm thats unfortunate for you. With a Metz58 it automatically cancels rear curtain and starts shooting 1/180.
06-30-2009, 06:30 PM   #38
octavmandru's Avatar
QuoteOriginally posted by krypticide Quote
I get rear curtain 1/90 sync with Metz. So...
06-30-2009, 07:07 PM   #39
Well maybe I'm wrong then and there is a second flash improvement in addition to the PC port for those who upgraded from the K10D. I hit the wall at 1/90 even with the pop-up on my K10D. Can anyone else with a K20D confirm 1/180 sync in rear curtain sync mode?
06-30-2009, 07:08 PM   #40
QuoteOriginally posted by octavmandru Quote
Which body are you shooting?
06-30-2009, 07:27 PM   #41
The K200D. And Metz 48. And I need to cancel manually the rear curtain to get 1/180 sync.
06-30-2009, 08:40 PM   #42
krypticide's Avatar
Doh, I realized that I was setting rear curtain sync wrong. I had it in-body, but not on my Metz. Once I set it on my Metz, the shutter speed went to 1/100th.
The other thing that bothers me is that rear-curtain sync can't be done when triggering a flash manually (e.g. wirelessly).
07-01-2009, 06:17 AM   #43
I subscribe to this. I can see many situations where you'd like to take the flash off the camera for a rear sync.
For a shot of a speeding car, for ex. This is the main ideea for the function, after all. I guess is difficult to implement this kinda communication.
07-01-2009, 06:33 AM   #44
QuoteOriginally posted by bentax Quote
Hmmm, that may be a feature of the Metz58. I wonder how they override the camera settings. The reason I decided against the 58 myself was the max sync speed of 1/125 at full power. What body are you shooting?
07-01-2009, 11:37 AM   #45
QuoteOriginally posted by kittykat46 Quote
If I'm not mistaken, the technique in the shot above involves deliberately underexposing the surrounding ambient light using high shutter speed, at the same time brightening up the subject to "normal" using the flash.
Sure, it can be done with Pentax, with a few limitations.
sorry to threadjack, but i stumbled on this earlier and excitedly just drove to the nearby park on my lunch hour to try it ...and it didn't work. My K10D kicked back to 180th/second every time i hit the shutter. my 540flash was mounted directly onto the camera. Was that the problem? Or did I miss something??
camera, curtain, dslr, flash, mode, photography, shot, shutter, sync
Slow speed sync Charles1 Pentax Camera and Field Accessories 2 08-07-2010 10:09 AM
can sync speed be updated? levelred Pentax DSLR Discussion 8 04-07-2010 09:57 PM
K7 Sync Speed brofkand Pentax DSLR Discussion 21 01-05-2010 04:37 AM
P-TTL and Sync Speed theprisoner6 Troubleshooting and Beginner Help 3 07-22-2009 12:52 PM
24 hs to bet about the x-sync speed! vitalsax Pentax News and Rumors 5 05-18-2009 06:33 PM
All times are GMT -7. The time now is 06:42 PM. | See also: NikonForums.com, part of our network of photo forums!
