06-29-2009, 03:32 PM   #1
eccs19's Avatar
*istD metering issue
Well maybe not an issue, but not sure.
A few weeks ago I had an issues with the camera not responding correctly, and just not working. When I finally got it working, all seemed OK minus this one issue. I'm not sure if just some setting in the menu got messed up, or if I've got another issue.
When I'm using my Takumar lenses, if I've got it in AV mode, I get a different shutter speed showing up between the view finder, and the display on top of the camera. The one that shows up in the view finder seems accurate, but the one on top seems to read way to fast. (If I remember correctly) I have to switch it to manual, and dial the speed in correctly. Also if I'm in manual, and I use the green button, it sometimes doesn't seem to meter correctly either, it seems hit and miss. Any ideas?
06-29-2009, 03:52 PM   #2
jeffkrol's Avatar
QuoteOriginally posted by eccs19 Quote
I'll have to check my D but when you remove your eye from the viewfinder (like to look at top lcd) light leaks in through the eyepiece. Will change the metering..
06-29-2009, 06:49 PM   #3
eccs19's Avatar
QuoteOriginally posted by jeffkrol Quote
I would expect a bit of change, but it's more than just a bit. Viewfinder will read 250, and top panel will read 2000 or higher.
06-30-2009, 06:02 AM   #4
jeffkrol's Avatar
W bright backlighting mine can go from .5 to 1/15th sec. 2000 seems a bit high.
Could be a malfunction though. some DS's had the metering panel come loose from the prism causing major errors. Have you replaced the little lithium battery in the bottom yet? istD does have a "backup" battery, unlike any other Pentax DSLR.
06-30-2009, 06:09 AM   #5
Lowell Goudge's Avatar
I have 2 observations
first of all, are you sure when you take your eye from the viewfinder and look at the top display, the camera is pointed in the same direction?
second comment one reply shows a change from .5 sec to 1/15 with back lighting, this is 3 stops.
1/250 to 1/2000 is also 3 stops, so 1/2000 is not excessive, it is the same as what someone else measured
06-30-2009, 07:43 AM   #6
eccs19's Avatar
Definitely pointing in the same direction. (tripod)
Next time I notice this happen, I'll cover the eye piece and see if it brings it back down. The thing is that I never noticed this issue prior to when I had the camera lock up on me, so I thought that in itself was kind of fishy. I'll change the small battery as jeffkrol suggested. I've never done it, so it can't hurt anyways.
camera, dslr, finder, issue, photography, view
Spotmatic F Metering Issue Periodista Pentax Film SLR Discussion 4 09-22-2010 04:18 PM
Help - Metering issue neoyoda Pentax DSLR Discussion 7 09-18-2010 12:52 PM
ZX-M metering issue LMRacing Pentax Film SLR Discussion 5 09-13-2009 07:41 PM
Issue with *istD eccs19 Pentax DSLR Discussion 4 06-22-2009 02:33 PM
*istD and stop-down metering pocky Pentax DSLR Discussion 6 06-20-2009 01:02 PM
All times are GMT -7. The time now is 03:23 PM. | See also: NikonForums.com, part of our network of photo forums!
