Originally posted by Buddha Jones If you have one battery like I do, you can run the camera with the battery in the grip so you dont have to take it off when you want/need to recharge the battery. Which I havent yet and its been alomst a month, that is freaking awesome.
I have neither the K10D nor the grip (yet) but the two-battery solution I see is to set the camera to use the grip battery first. By the time you've depleted both batteries, removing the grip really won't seem a chore.
Also, if you remove the grip to travel light, you've a fully-charged battery in the camera. If you remove the grip before leaving home, you can charge the grip battery, then swap out the camera battery when you get back to base.
Personal weight tolerance and ergonomics aside, the grip seems useful (especially with current rebates). I hope to check out a K10D/grip combo at my local dealer today or tomorrow.
Daryl
