Originally posted by dlacouture Steve : this is a pretty common statement, but it's totally false... Try this in plain sunlight (on a very bright objet), and you'll still see the same behavior, even though the light coming through the lens is way above the Ev bottom limit of the sensor...
Moreover, using a LL60 removes this flattening... So this is really an effect of the stock screen.
Totally false? Well, perhaps I should redo my controlled exposure series tests that the statement was based on. My results showed that the severe underexposure at smaller apertures (3 stops under at f/22 on one test), essentially went away in bright light. With adequate light at f/8 and narrower, the general pattern was for correct exposure or a mild over-exposure (~0.5 stop).
As far as the LL60 removing the flattening...I don't particularly want to be contrary, but I calculated the EV at the sensor and it was below EV 0 (ISO 100) at those smaller apertures. According to the published specs for the K10D, I think that is below meter sensitivity. Moreover, my tests seem to indicate that the K10D sensor becomes non-linear at about EV 1.5 (ISO 100) which does not help matters any.
(I guess I really should publish my exposure series graphs...)
