07-05-2009, 08:28 PM   #16
QuoteOriginally posted by Edvinas Quote
No, it does not. Set to P and adjust shutter speed. Increase it. First, camera will be opening lens aperture. When the widest lens aperture is reached, Auto ISO should kick in and increase sensitivity. However it doesn't and you're not allowed to increase shutter speed anymore.
What you are describing sounds like a reasonable behavior, but I don't think it reasonably qualifies as a bug. A limitation of a feature yes, but a failure of a documented feature, no. As noted above from the manual:
"You can only set the shutter speed to a value that will give a correct exposure with the aperture range of the lens being used."
My big question is why anyone would want to use hyperprogram that way. If you already know the preferred aperture and shutter speed, why not just use TAv mode?
07-05-2009, 10:37 PM   #17
lol101's Avatar
A reasonable behaviour would be that HyP should react like Tv when using one wheel, Av when using the other... regardless of using auto-ISO or not.
In auto ISO, ISO increases when you hit max aperture in Tv but not in HyP/Tv: that should not be the case, they should just behave the same.
The best proof of that is that Pentax apparently corrected this wrong behavior on the K-7.
As for the reason one would want to use the camera this way, well... why not?
07-06-2009, 01:42 AM   #18
You're completely missing the point.
lol101 already wrote: the essence of hyper program is that you seamlessly switch to Av (aperture priority) when you turn one wheel and to Tv (shutter speed priority) when you turn another wheel. It's that simple.
Tv (shutter priority mode) must behave the same, it should not be different wether you choose Tv with mode dial or shoose Tv in Hyper program by turning front wheel.
In K10D/K20D Tv and P->Tv behaves differently and that is a bug. In K-7 both Tv and P->Tv acts identically.
07-06-2009, 01:47 AM   #19
Arpe's Avatar
QuoteOriginally posted by nostatic Quote
Well, when you hit the button the flux capacitor charges and sends 1.21 gigawatts to the hyper-drive, allowing you to change the shutter speed to 1/1,000,000 of a second until it melts down and explodes at twice the speed of light.
It's not a bug, it's a feature.
LMAO!!
07-06-2009, 12:30 PM   #20
For me it's clearly a bug. And they fixed it in K-7. K-7 P mode acts exactly the way I expect it to act.
To you, it probably is. To everyone else, I'm not so sure. HyperP is not the same as Tv, and NOWHERE was it advertised to work *identically* as Tv.
A bug is something that doesn't work as specified. You can say it does not meet your expectation, that's fine, because expectation is subjective.
However, saying that something is a bug needs an objective measure. Unless there's a proof that it works differently than a specification or an advertisement, it's not a "bug".
How do you know there aren't a sizeable number of people who like the behaviour of the K20D HyperP? They may complain there's a "bug" in K-7, because they expect the ISO to remain unchanged and not make their images noisier - when instead it's just not meeting their subjective expectations.
So, your complaining that it's a "bug" on a K20D is just like those who're used to the way things work on the K20D complaining that the K-7 has a "bug".
The K-7 is just designed differently. To fix a bug is not the only reason why behaviours can be updated. So apparently the K-7 having this behaviour changed cannot be used a as "proof" that the K20D behaviour is defective.
It's just like saying because the K-7 has a 100% viewfinder, the 95% viewfinder on the K20D is a bug.
07-06-2009, 05:33 PM   #21
Arpe's Avatar
Seems strange then in the K20D that auto-ISO works differently in Hyper-programme between the Av mode and the Tv mode intitialised by the turn of one of the dials. Also strange if it wasn't "broken" in the first place, that they have now fixed it on the K-7.
07-06-2009, 10:43 PM   #22
lol101's Avatar
QuoteOriginally posted by wolfier Quote
It is the very essence of HyP to offer seamless switch between a classical P mode, Tv and Av, at least it is the way Pentax advertise it since 1992.
Maybe they changed their philosophy on the K10/K20 to "HyP allows the user to switch seamlessly between P, Tv and Av... except for Tv with auto ISO where it doesn't quite react like the Tv mode..." but it looks a little bit too complicated to suit Pentax's straightforward and rather intuitive ergonomics IMHO... my vote also goes for a (rather small) bug...
It is always amazing to see to what length some will go to justify that Pentax always do the right thing... even if Pentax themselves acknowledge the "problem" and come up with a fix... :ugh:
OK, OK, this is no bug, it's a feature that differentiate Tv from HyP/Tv... we're just happy that it was corrected on K-7
07-06-2009, 10:51 PM   #23
QuoteOriginally posted by lol101 Quote
Well, if you look at my post history here and on dpreview, I'm hardly the type of posters who think Pentax always does the right thing. A lot of my posts get rebuked by RMabo over there, if it means anything to you in this regard.
But plainly calling something a "bug", without an objective specification, irritates me from an engineer's perspective. We see a lot of these complaints from overly arrogant users who think their subjective point of view is a good representation of the entire population.
07-07-2009, 05:08 AM   #24
falconeye's Avatar
With front e-dial decrease shutter speed to 1/30. aperture will stay at f/2.8, ISO will become 200. Then try to go back to initial shutter speed 1/60s. Camera won't allow this.
I wasn't aware of the issue.
But after Edvinas excellent description of the bug in post #13, how can anybody still be argueing about it?
Shaking head ...
07-07-2009, 06:18 AM   #25
Shaking head ...
Yep, I thought that after step-by-step description how to reproduce that bug, people at least would try to reproduce it and to understand what hyper program really is.
Most funny, that they are telling that we're wrong, however themselves they don't really know and can't explain what the Hyper Program is.
Take a look here. Links to official pentax explanation what Hyper Program is for K10D, K20D and K-7:
K10D : Digital SLR Cameras : PENTAX
K20D : Digital SLR Cameras : PENTAX
K-7 : Digital SLR Cameras : PENTAX
As you can see it's absolutely the same for all cameras and the whole point of Hyper program is that you can seamlessly switch to Tv or Av by turning wront/back wheels, without playing with Mode dial. It is that simple. No need to create mystic about Hyper Program.
Many people don't use Auto ISO and they would never encounter bug we're writing about. Many people who use Auto ISO actually don't understand the algorithm how Auto ISO works... and then start to create stories about Pentax not increasing ISO because they don't want to make images nosier... Why then Pentax implemented Auto ISO at all?! Don't just read manuals, they don't tell many things, use your camera and most importanly use your brain
Anyway, I am happy that in K-7 they have fixed it
07-07-2009, 06:36 AM   #26
falconeye's Avatar
But the brain is horribly complex and didn't come with a user manual.
07-07-2009, 05:47 PM   #27
Arpe's Avatar
I don't call it a "bug". I call it an outright error, mistake or Monday Programming, which should have been fixed in subsequent firmware updates.
07-07-2009, 06:44 PM   #28
Class A's Avatar
QuoteOriginally posted by Arpe Quote
I call it an outright error, mistake or Monday Programming, ...
In software development all of the above is referred to as a "bug".
...which should have been fixed in subsequent firmware updates.
Lord knows why they don't provide such updates. Perhaps you should look at it positively and view it as an excuse to update to the K-7. Say "Thank you Pentax, for giving me an excuse."
07-07-2009, 06:51 PM   #29
nostatic's Avatar
Marketing department calls it a "feature"
07-07-2009, 07:20 PM   #30
As a programmer, I'd call it a "feature" as well.
I agree w/ Edvinas though. Pretty dumb not to fix it in the K20D firmware...such a simple fix...
auto, bug, camera, cameras, dslr, iso, k-7, mode, pentax, photography
Auto ISO in manual mode yusuf Pentax DSLR Discussion 37 03-10-2012 05:44 PM
[Auto-ISO] so, is the K5 and Kr brave enough to use max iso? Reportage Pentax K-5 13 10-24-2010 03:30 PM
k20d auto ISO in TAv mode wiyum Pentax DSLR Discussion 10 08-13-2008 05:18 PM
auto ISO in M mode? not option? Akcelik Pentax DSLR Discussion 4 03-07-2007 05:38 PM
K10D. Bug with Auto ISO in P mode? Edvinas Pentax DSLR Discussion 21 12-30-2006 05:47 PM
All times are GMT -7. The time now is 12:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
