07-07-2009, 07:31 PM   #1
dichro1's Avatar
Using M lens with K10D
I have a K10D and recently got a Pentax-M 28mm lens, k-mount lens.
I choose the 28mm SR setting, and press the AE-L before the shutter button, but I cannot get a meter reading, whether the diaphragm is stopped down or not.
The "allow f-stop ring" is activated. The diaphragm does close down when the shutter releases. If I set the right diaphragm - f-stop settings the exposure is right. But the camera gives me no clue as to the setting. Do I have to get a manual meter?
The manual gives no clue, a forum indicated that the meter should at least show a desired setting. ?????
07-07-2009, 07:51 PM   #2
QuoteOriginally posted by dichro1 Quote
M mode?
07-07-2009, 08:09 PM   #3
Stefan Carey's Avatar
M mode should do it
You aperture will be on the lens itself, and will not show up on screen.
I think there might be a workaround for shorting out a contact on the lens to give you this information, but I have not tried this.
07-07-2009, 11:30 PM   #4
Marc Sabatella's Avatar
First, AE-L doesn't do anything that I am aware of on the K10D when using manual lenses. The function performed by AE-L on older cameras is performed by the Green button on the K10D - it will stop down temporarily, take a meter reading, and set an appropriate shutter speed for you. But it won't display a meter reading for the current settings - to do that, use the DOF preview.
Check on the sticky thread in the beginner's forum for more on using manual lenses.
07-08-2009, 09:07 AM   #5
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/59272-shooting-...x-dslrs-f.html
28mm, camera, clue, diaphragm, dslr, f-stop, k10d, lens, meter, photography, shutter
For Sale - Sold: K10D body, DA 18-55mm kit lens, Tamron DiII AF18-250mm lens; Tamrac Velocity 8 gimmepizza Sold Items 9 12-01-2009 05:26 AM
Wide-angle lens to replace K10D kit lens StacyA1973 Pentax SLR Lens Discussion 20 03-07-2008 02:43 PM
Lens for K10D EAD Studios Pentax SLR Lens Discussion 16 01-08-2008 08:36 PM
Newb AF lens question about lens for K10D pentaxbling Pentax SLR Lens Discussion 3 08-15-2007 05:52 AM
All times are GMT -7. The time now is 02:13 AM. | See also: NikonForums.com, part of our network of photo forums!
