10-18-2009, 07:48 PM   #511
Class A's Avatar
QuoteOriginally posted by brecklundin Quote
That would be good info to be had if you could find the thread.
Might not be the one but here's an example for light entering through the viewfinder (rather long exposure, though).
10-18-2009, 08:03 PM   #512
jeffkrol's Avatar
QuoteOriginally posted by min.t Quote
Hi all,
I've just bought a k7 and have promptly updated to the latest 1.01.xx13 firmware version.
however, to my horror, i have not just a green line, but a green banding halfway through my outing. (after ard 20mins of keeping the camera on. LV was off). Did i get a more serious case of the GLS?
Some points to note:
1) my shots at the start of the night did not have any visible banding.
2) the green banding appears at all high ISO
3) the green banding was only visible in my nightshots of the sky. i didn't note any banding when i shot in slightly brighter situations (at ISO800)
4) when i got home, i tried to shoot in low light and in darkness on dark objects and there was no green band.
Attached is a sample of a photo with the green banding:
Can someone shed some light on the situation? Is a trip to the service center unavoidable?
As suggested here:
Re: Back it goes: Pentax SLR Talk Forum: Digital Photography Review
Bad sensor, send it in......
10-19-2009, 02:11 AM   #513
bentax's Avatar
Yeh mate send it in. I wish I'd sent mine back when i noticed the problem. This body seems plagued with glitches. Horizon correction and level is out of whack and Shake Reduction is faulty.
10-20-2009, 07:15 PM   #514
THANKS...that thread exposes quite a bit of info and is very illuminating.
10-21-2009, 06:11 PM   #515
Just got my K-7. It came with 1.00 and had obvious green banding issues across the top third of the image. Installed .13 and it immediately went away. Very pleased, though I'll keep an eye on it.
10-21-2009, 06:16 PM   #516
jgredline's Avatar
QuoteOriginally posted by deadwolfbones Quote
You are going to love it!
10-21-2009, 07:23 PM   #517
paugie's Avatar
congrats, Ben, on the K7. so you won't have to be shooting with the K100D now.
10-21-2009, 10:06 PM   #518
QuoteOriginally posted by paugie Quote
I was actually enjoying the K100D today and looking forward to using it for the rest of the week. Then I came back from lunch and there was a big ol' box on my desk. Oh well, plans change...
10-28-2009, 11:25 AM   #519
Has anybody with geen banding/line that wasn't solved with .13 firmware tried the new 1.02 firmware? My K-7 is still in Paris for service, I would like to know does the new firmware helps at all?
10-28-2009, 07:26 PM   #520
QuoteOriginally posted by Jadran Quote
A K-7 user in my locality had a green line problem which persisted right up to V1.01.13 - he was getting really frustrated, but V1.02 seems to have fixed it for good.
Looks like there were K-7 bodies with different extents of the problem. Pentax released successive fixes and the "official" V1.02 may be the final fix.
I suppose anyone who still has the problem after this has an abnormal unit, and should have it repaired.
10-29-2009, 11:45 AM   #521
QuoteOriginally posted by kittykat46 Quote
Thanks, it sounds encouraging!
10-29-2009, 12:21 PM   #522
Sometimes I am wondering if this green line problem actually is a hardware design flaw (something like low heat tolerance of the sensor) and Pentax is trying to fix that on the software level....
10-29-2009, 07:09 PM   #523
QuoteOriginally posted by cbaytan Quote
There is no evidence of any degradation of Image Quality with the successive firmware fixes - plenty of people have pixel-peeped. So I'm pretty confident the solution wasn't done by "covering up" any sensor problem via software.
Given that different bodies seem to have different extents of the problem (or none at all) there certainly seems to be some circuitry tolerance involved, but it may not be the sensor at all.
It sounds to me like some defect caused by the way the firmware controls the data readout from the sensor, exacerbated by tolerances in the physical circuitry (or no problem at all, with many users, myself included).
When I was involved with high-end computer graphics cards years ago, some models exhibited a Green or Red vertical line under certain conditions. It was a circuitry clocking problem, with some parts of the circuit not working at the same speed. A firmware update fixed the problems out in the field, and the design engineers tightened the tolerances on a few components.
Probably what Pentax is doing in this case.
10-29-2009, 10:36 PM   #524
LeDave's Avatar
When I bought my K-7 and it had about 230 actuations, 1.00 firmware, and no green banding. I was very pleased with it, I guess not all units are affected by the green banding with 1.00.
10-30-2009, 02:47 AM   #525
falconeye's Avatar
QuoteOriginally posted by LeDave Quote
Firmware 1.00 has the green line fix applied starting at version 1.00.00.08. New units shipping with 1.00 have no green line artefact as they are tested against.
The minor versions (I've seen 00, 04, 05, 08, 09, 13, 14 now) may be a more accurate way to quote the firmware version. E.g., 14 is 1.02.00.14.
body, camera, dslr, iso, k7, line, photography, sensor
Sony outsources some sensor production to Fujitsu deadwolfbones Pentax News and Rumors 10 10-02-2010 03:24 PM
Samsung's new BSI (backside illumination) CMOS sensor will be in production by 2010 yakiniku Pentax News and Rumors 7 10-15-2009 09:34 PM
HELP!!Busted my DA* 16-50 pentaxpaul Pentax SLR Lens Discussion 10 03-02-2009 10:21 AM
Busted! pingflood Post Your Photos! 7 01-03-2009 09:57 PM
ZX-10 Busted? ericc Film SLRs and Compact Film Cameras 1 12-01-2006 11:41 AM
All times are GMT -7. The time now is 11:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
