07-10-2009, 04:08 PM   #16
I too have the K100D and just received the K2000/KM. I experienced the same frustrations when I compare pictures from these two cameras with the same settings indoors (evenings) using my Tamron 28-75mm lens. I only shoot jpegs.
With the K100D, my default setting was iso 400 since the camera constantly underexposes. With the K2000, like my canon G10, I can't go above iso 200. Still experimenting to achieve sharp pictures at iso 400. Using the manual mode, the K2000 overexposes compared to the K100D which gets it right on.
I also found that the K2000 on auto iso, at least indoors, is another problem as the camera keeps selecting iso 800. On the positive side, the camera shutter is quite snappy.
07-10-2009, 04:40 PM   #17
I think people are right. The actual amount of noise is magnified by viewing more closely. At the same time, when viewed at printing size, you will find the noise equivalent between the K100 and K2000. If you really want total control, you are best shooting in raw and deciding what level of noise reduction (if any) you want to use for a given photo. The reality is a little grain in a picture is not a bad thing and may not detract from the overall effect.
07-10-2009, 05:06 PM   #18
LeDave's Avatar
I think turning off shadow compensation and turning up the Noise Reduction helps.
camera, dslr, iso400, noise, photography
K2000 NR WillCarney Pentax DSLR Discussion 1 01-26-2010 02:53 AM
K2000 Duane Pentax DSLR Discussion 6 12-20-2009 05:28 PM
K2000 Noise,help winglik Pentax DSLR Discussion 14 08-27-2009 03:31 PM
Strange noise coming from the K2000 pentaxNasson Pentax DSLR Discussion 16 02-13-2009 02:45 AM
cs3 noise filter vs. noise ninja vs. ??? reknelb Pentax DSLR Discussion 0 03-04-2008 04:55 PM
All times are GMT -7. The time now is 01:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
