07-12-2009, 11:47 AM   #1
PentaxPoke's Avatar
1/8000 s can be fun...
Focus is on the water, not the head. This is approaching flash speed!
Anyone else care to post stop-action shots (no flash) with the new 1/8000 capability of the K-7?
07-12-2009, 12:49 PM   #2
These are taken with the K10D so not 1/8000th but around 1/4000th as I'm still waiting for my K-7. Lens used it the 35mm Macro LTD. All photos taken using a clear plastic tank filled with water with object dropped in, camera pre-focused and shutter pressed manually by guess work.
I can't wait to try some of this stuff with a K-7 and the 1/8000th shutter speed.
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K10D  Photo
07-12-2009, 01:55 PM   #3
bdery's Avatar
The corks are extremely well done, and really cool! I should try that someday.
07-12-2009, 02:32 PM   #4
This thread promises to be fun. These images are great.
07-12-2009, 02:43 PM   #5
PentaxPoke's Avatar
dopey those shots are awesome! They stop action so well, they seem to be flash-based. Makes my shot seem boring. I look forward to you getting a K-7 as well...
07-13-2009, 02:22 AM   #6
I did a whole 2 month project on high speed photography (for my Final Major Project at College a few weeks ago and won the Fine Art Photography Award starting with using a manual flash to freeze water droplets but this only works in a dark environment as using flash in daylight the daylight overpowers the flash leaving blurs etc. I then discovered I could just use this tank for several shots with a high shutter speed but it wouldn't have worked say if I'd of put a black piece of card behind becasue there wouldn't be enough light.
If you want to try this get a cup fill it 3/4 up with water then get an assistant to drop something anything into the coin having pre-focuses the camera on a tripod with a high shutter speed and get used to manualy clicking the shutter at what you think is the right time. It's a bit hit and miss but it gives some amazing results.
There's a few more from this series on mywebsite under misc.
camera, dslr, flash, photography
New Photo Contest$8000 in Prizes from IPA pressphotog Photographic Technique 5 10-06-2010 02:59 PM
Which one? Lumix DMC-FT2 vs Olympus Tough 8000 vs Pentax W80 raider Pentax Compact Cameras 8 05-04-2010 10:52 PM
800$ vs 8000$ tppentax Pentax DSLR Discussion 32 12-11-2008 10:38 AM
Ringlight final test... fun fun fun! codiac2600 Post Your Photos! 16 02-04-2008 12:33 AM
Fun with my A-50 f/1.4 silverbullet Post Your Photos! 1 08-22-2007 02:55 PM
All times are GMT -7. The time now is 10:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
