07-12-2009, 07:29 PM   #1
K7 Wireless Flash Problem
Dear Pentax users,
My newly acquired K7 has the following problems in wireless flash mode with my AF-540 FGZ:
1) Channel setting cannot be memorized
When I set the wireless channel in the K7 to channels other than 1, K7 cannot memorize the settings and go back to the default channel 1 after power off.
2) The P-TTL seems does not work in wireless flash mode
The images are severly overposed (estimated by 2-3 stops). The built-in flash on my K7 is customised to Control mode. The flash however works perfectly when attached to the hotshoe.
Any K7 users have the same problems? I am just wondering if it is just a problem to my K7 only or it is a bug in the K7 wireless flash mode in general.
Thanks in advance for your feedback.
07-13-2009, 04:44 AM   #2
mattdm's Avatar
Have you gone through the process of setting the channel on the flash and body together? I found when my Metz 48 AF-1 came back from service, it appeared to work in wireless P-TTL but was firing only at full power -- sounds like just what you're seeing. "Re-introducing" the camera and flash made everything work again?
07-13-2009, 06:58 AM   #3
Thanks. Just gone through the channel setting process again. I let the flash stayed on the hotshoe longer before I turned off the flash and the camera. The camera can memorize the channel this time. However, the same over-exposure problem still exists. The P-TTL still doesn't seem to work properly.
07-13-2009, 10:10 AM   #4
Just out of curiosity, please try wireless with the flash in A mode and report back. Thanks.
07-13-2009, 02:28 PM   #5
PentaxPoke's Avatar
I just checked mine. Channels work ok but I see the same overexposure problem. On-camera, the P-TTL is perfect. Off camera, I need to dial in -1 EV on the flash page on the K-7.
07-15-2009, 03:17 AM   #6
what mode is k7 in, also check iso make sure same.
to q1 can that memory be selected on/off in pf menu or user menu?
07-15-2009, 03:57 AM   #7
mattdm's Avatar
Hmmm. Have you checked with Pentax support? I'm curious what they say.
07-15-2009, 05:34 AM   #8
RBellavance's Avatar
For what it's worth, I have the same overexposure problem in wireless mode with my (chipped for K10D) Sigma EF-500 DG SUPER.
Not that this really surprises me, given that it's a 3rd-party flash.
07-15-2009, 08:12 AM   #9
Regarding the over exposure issue: Have you made sure the wireless flash mode of the 540fgz is set to PTTL and not just "dumb slave" ? Hold down the light-key until SL appears in the display, it should read "1" or PTTL and "2" for dumb slave if I remember correctly. (It might be the other way around though)
07-18-2009, 08:05 AM   #10
QuoteOriginally posted by sveinmb Quote
Thanks for everyone's help on this issue.
The SL is set at 1. Indeed, I have replaced my K7 with a new one. However, the over-exposure problem still exits. Having done some tests during the past few days. Interestingly, off-camera direct flash looks fine, only off-camera bounce flash is over-exposed. It needs -2ev compensation in the camera's flash control to correct.
camera, channel, dslr, flash, k7, mode, photography, users
K-x with new metz 58 AF-1 wireless problem shawnrnicholas Flashes, Lighting, and Studio 5 10-29-2010 01:16 PM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
studio strobe wireless problem Mystic Pentax Camera and Field Accessories 3 01-08-2010 05:40 AM
Can we set the internal flash of K-7 not to flash while connecting wireless with 360? raider Flashes, Lighting, and Studio 12 11-15-2009 09:31 AM
Wireless trigger problem with Pentax 540 flash m42geo Flashes, Lighting, and Studio 7 07-03-2009 02:08 AM
All times are GMT -7. The time now is 12:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
