07-14-2009, 01:40 PM   #1
Help required!
Im looking at getting a new DSLR to replace and old pentax SLR.
I have a few lenses for my SLR, a vivitar series 1 70-200mm and a wide angle (cant remember the size).
My question is, would I be better getting a new lens collection, or continue to use these lenses, as well as my kit lenses for the time being.
I will mainly be doing landscape (alot of which will be low light, early morning/late evening) photography and shoots of cars (parked, stationary), with the occasional portrait and low light/night city shots (these two are very rare occurrences).
Is the K20d a good choice for these circumstances?
I have read sevral reviews saying the k20d/gx20 performs badly in low light, is this ture?
And i will be mainly shooting RAW.
And I am still debating between the gx20 and K20d.
07-14-2009, 01:46 PM   #2
Looking at this thread https://www.pentaxforums.com/forums/pentax-dslr-discussion/64295-pentax-high-...post-here.html
High ISO dosent seem to be a problem.
07-14-2009, 01:49 PM   #3
graphicgr8s
Guest
I'd get the K20D myself.
Some of the Vivitar lenses have a "shroud" on the mount that prevents it from going onto the digitals. You just have to cut it off.
07-14-2009, 11:26 PM   #4
Dont think I want to be doing that.
The kit I am looking at comes with 18-55 and a 200mm zoom lens. So if my wide angle lens fits, thats great.
But I dont want to be damaging my vivitar.
07-14-2009, 11:32 PM   #5
pbo
pbo's Avatar
Or simpler, just screw it off - not the whole mount, only the part that holds that "shroud", it's quite easy if you have a small screwdriver. There's like three screws holding the black part of the mount with "shroud", and three other screws that hold the rest, silver, part of the mount. Screw off the former three and stay away from the ones that hold the lens mount, and you should be okay.
Bo.
07-15-2009, 09:35 AM   #6
I have found a gx-20 $150 cheaper than a k20d, is the k20d worth the extra $150, because I dont need compressed raw, so I cant see an advantage for it over the samsung?
07-15-2009, 09:44 AM   #7
ANY pentax Dslr will do...
If you really only care about the mentioned usage, then I dont see any body features that would matter to you.
The only low light usage you list is landscape and night shots... both of these are going to require heavy intervention by you with metering. In other words, you arent going to put any camera on 'P' and get the shot you want in these circumstances.
Also, these do not require fast Autofocus. So the K20's low light performance should be just fine!
I think you are just buying the sensor... so do you want 14.9, 10 or 6MP? the extra resolution of the 14.9 may be noticeable in your landscapes, depending on how you view them.
so I would say K20D if you want resale value, or GX20 if you just want least expensive.
-k
07-15-2009, 01:39 PM   #8
Meaning what?
I thought the GX-20 and K20d were almost identical?
camera, dslr, k20d, lenses, light, photography, slr
Required Thread MdltnDrvr Welcomes and Introductions 5 10-06-2010 11:41 AM
How much is really required? Jetsam1 Digital Processing, Software, and Printing 22 07-15-2010 11:54 AM
Advice required Naim Khan Pentax SLR Lens Discussion 15 03-25-2010 10:03 AM
Help required - Sigma 28-70 f2.8 5teve Pentax SLR Lens Discussion 2 08-20-2009 05:11 PM
constructive critisism required timk Photo Critique 6 08-03-2009 03:48 PM
All times are GMT -7. The time now is 05:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
