Originally posted by jstevewhite After reading this thread I'm somewhat surprised. I've never had the slightest trouble with green-button metering on Pentax-M lenses with my K20D. I had (recently sold out all my old glass and bought new stuff) the M 50 1.4, the M 100 f4 Macro, the M 135 f2.5, and I have a Tamron 180 f2.5 with a P/K-M mount on it, and they all expose flawlessly - that is to say, very similar to my Pentax FA and DA lenses.
Did you run those lenses stopped way down? My guess is that you shot mostly wide open or between there and f/8 or so, in which case you wouldn't have noticed it so much. Also, you wouldn't notice it if you had a Katzeye or other focus screen installed. But if you still had any of those lenses, you might try actually running the test all the way through the aperture settings. I suspect you'd find more variation than you expect.
Quote: I'm surprised because this would (should!) be the absolute easiest way to meter accurately, as you're measuring actual incident light, not predicting the amount of light that WILL be available.
True, but that light is measured through a focus screen that was not really designed to be metered at anything but wide open. That's why replacing the focus screen solves the problem.
Quote: I would have been quite upset to discover that it metered inconsistently with those lenses. Consistent behavior I can compensate for - inconsistent behavior makes that impossible!
Oh, it's consistent in that a given lens at a given aperture always over- or under- exposes by the same amount. But the amount and direction to which a lens is off varies with the lens as well as with the aperture, so you can't just say "all manual lenses always overexposed by 1 stop" or anything like that.
