05-06-2007, 02:16 PM   #1
ist DL manual focus
Hey guys,
I can't get anything into focus manually on my ist, the diopter is correct. What I see as focused isn't, the auto focus works fine but I would like to use manual lenses too. Also I have an old pentax 35mm that I can focus fine. Any ideas?
Thanks
J
05-06-2007, 06:20 PM   #2
borno's Avatar
Could the focus screen be in wrong? It should be shiny side towads the mirror. Just a thought.
05-06-2007, 06:51 PM   #3
When your using manual focus are you judging with your eye that the picture is in focus or are you using the focus indicator in the view finder?
Sometimes i have found even when a picture looks in focus often when you see it at 100% it isnt. I have learnt to use the focus indicator to check.
hope this helps.
05-06-2007, 07:10 PM   #4
focus
QuoteOriginally posted by ossi Quote
hope this helps.
Thanks,
If I judge with my eye it is wrong, if I use the indicator it is right. I will check the focus screen. Thanks for your help. No one else experiences this then huh?
Jeff
05-06-2007, 07:53 PM   #5
rfortson's Avatar
QuoteOriginally posted by jeddy Quote
Thanks,
Jeff
That sounds like the diopter isn't adjusted correctly.
05-06-2007, 08:36 PM   #6
QuoteOriginally posted by rfortson Quote
I can see everything in the view finder correctly.... I have tried all of the positions.
J
05-06-2007, 10:59 PM   #7
Thanks,
Jeff
I havent used manual focus lenses a lot on the DL, i have used a 500-800 mirror lens and experienced similar behaviour. I was attempting to photographer surfers a long way out, it looked like they were focused but then got home and looked and they werent. I didnt think too much of it becuase with a lens of that focal length and the surfers appearing that small there is very little depth of field and so easy to get things out of focus.
Does the object look out of focus through the viewfinder when the focus indicator is illuminated? Or does the object look in focus? what lens(es) are you using?
05-07-2007, 06:42 PM   #8
No, when the indicator is lit (and is properly focused) I can not see it in focus.
Thanks...
Jeff
05-07-2007, 07:55 PM   #9
LeoTaylor's Avatar
I've used many a manual lens on my K100D. The Pentax instructions for DIOPTER adjustment are poorly worded. Here are my methods:
If you have an autofocus lens let it focus (push shutter half way) then adjust Diopter so your eye is focused.
OR
With a manual lens adjust until the camera indicates focused (you mention that works fine) then adjust the DIOPTER to focus your eye.
Remember where it is set in case you bump it. Mine is one click left of center.
05-07-2007, 08:54 PM   #10
I do something a little differently. I actually try focusing on a point of the object. Like on a cat I'll focus at the eyes or whiskers. That's usually when the indicator lights up as well.
05-22-2007, 09:23 PM   #11
I just wanted to let people know that I figured out the problem just in case it happens to someone else. There is a u-shaped brass shim that was on the wrong side of the focus screen. This put the focus screen too far away from the lens. Thanks for everyone's reply, it is good to know that there are people willing to help.
Jeff
camera, dslr, focus, photography
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
Macro: Handheld, Manual Focus, Manual Stop-Down Mike Cash Post Your Photos! 2 06-19-2008 07:14 AM
Question on Ist-D focus confirmation on 3rd party manual K lens brainanta Pentax DSLR Discussion 13 03-21-2007 09:22 PM
All times are GMT -7. The time now is 12:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
