07-17-2009, 08:12 PM   #1
K100D pop up flash will not fire
K100D flash pops up but will not flash.
Any hints or easy fixes to try?
yes its on and up
Thanks
07-19-2009, 06:13 AM   #2
Check your flash mode using the Fn button + the down arrow.
If its in "Auto" it may not discharge if the camera thinks its bright enough.
Just close the flash and press the pop-button to force it into Manual discharge mode.
The other thing to check for is make sure your battery still has plenty of charge. It may be enough to operate the camera normally but not enough to fire the flash.
Other than that, if your flash still doesn't fire, I think its just faulty and needs to be sent back to Pentax for repairs if you want it functioning again.
camera, dslr, flash, k100d, photography, pop up flash
Help! KX Pop-up Flash TAP Pentax DSLR Discussion 2 05-26-2010 01:06 PM
K7 pop up flash @#%! ordinaryimages Pentax DSLR Discussion 12 04-05-2010 02:55 PM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
DSLR Repair centers.... K100D pop up flash issues 41ants Pentax DSLR Discussion 0 06-26-2009 07:41 PM
Help on the pop-up flash of my K100D cristolin Pentax DSLR Discussion 4 01-13-2009 02:29 PM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
