07-19-2009, 08:14 AM   #1
oppositz's Avatar
K10D - Mirror problem
After only about 30,000 pictures my K10D mirror locked up on me.
On the third shot of the day, my mirror flipped up and stayed there. The shutter is closed.
I've tried turing off/on, removing and changing the battery and some gentle taps.
While the camera is turned on there is a click and a slight pulse is felt every few seconds. I assume this is an attempt to return the shutter to its normal position.
When turning off the camera it takes a few seconds before responding to the switch. Turning on there is no sensor shake.
Anyone else experience this problem?
Was it an expensive fix?
I wasn't planning on replacing this camera for a couple years...
07-19-2009, 10:14 AM   #2
kent's Avatar
seems like shutter mechanism is gone
07-19-2009, 12:23 PM   #3
wlachan's Avatar
Not sure about the K10D but the mirror of MZ/ZX film cameras would stay up once the plastic gear on the mirror motor cracked (Pentax later issued a brass gear). If that was the case, you have no choice but to have it replaced cos it will be a complicated job.
07-19-2009, 12:30 PM   #4
oppositz's Avatar
K10D Mirror Problem
I hope you mean replace mirror motor gear, not whole camera...
Thanks, George
07-19-2009, 01:48 PM   #5
Ash
Community Manager
Ash's Avatar
Check to see how much it would cost to repair it - it may exceed the camera's current value.
camera, dslr, k10d, mirror, photography, shutter
K10D mirror flipping problem yyyzzz Pentax DSLR Discussion 1 04-11-2010 02:31 AM
K-7 shutter/mirror problem zerodaze Pentax DSLR Discussion 15 08-18-2009 05:54 PM
K10D mirror alignment problem? J2R Pentax DSLR Discussion 4 07-14-2009 09:42 PM
Mirror image problem Valojuova Troubleshooting and Beginner Help 17 02-24-2009 10:49 AM
Problem with K1000 mirror mhoy Pentax Film SLR Discussion 5 04-26-2008 07:19 PM
All times are GMT -7. The time now is 08:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
