07-19-2009, 01:13 PM   #1
K200D not closing the aperture
Hey gang! I currently have a problem with my K200D. I'm not really sure whether it is a camera problem or my lenses, but I'm pretty sure it is the camera since I tried 3 manual "A" lenses on it.
My k200d won't stop down the aperture on my FA and A lenses. I have tried all modes including M and it still won't. Even if I use the aperture ring and say dial it down to f/5.6 still the camera wouldn't adjust the aperture upon taking the shot.
On my DA*, everything works fine with the aperture stopping down during the shot. This makes me wonder what's with the DA* (or absent) that makes it work.
I btw have cleaned the contacts on the 3 A lenses, as well as the contacts on my camera. Hopefully someone here can help me.
Thanks!
07-19-2009, 02:33 PM   #2
Under your Custom Settings Menu, item 23, have you set 'Using Aperture ring' to 'Permitted'?
07-19-2009, 10:36 PM   #3
Sorry I forgot to mention that I also have tried this. Even if I don't permit using aperture ring the lens should have worked fine since I had it in "A." I tried using the aperture ring, and the aperture reading on the camera would change... but when I take a shot the aperture doesn't close.
07-20-2009, 12:19 AM   #4
My K200D does the same when set in Aperture Priority with my SMC M manual lenses. No matter what I do - DOF preview, green button - the lens iris doesn't close down in preview mode or at exposure time when set at the default Aperture Priority.
If I want the iris to stop down I have to switch to 'M' manual with my older lenses. Everything works OK then. I can then use the green button or the DOF preview to stop the iris down. Exposures work correctly on 'M' too.
fwiw.
07-20-2009, 07:52 AM   #5
fwiw.
Normally, it does as what you say it does. But mine doesn't stop down at all even in M mode. I guess nobody else has ever encountered this problem with their cameras. oh well.. hopefully it goes away coz the last time this happened it just went away after I cleaned the contacts. Not sure why it's not working this time though.
07-20-2009, 08:26 AM   #6
Check out this thread
https://www.pentaxforums.com/forums/pentax-dslr-discussion/67003-omg-aperture-lever-broken.html
It might help your problem.
Actually, that thread was a day ago. Pretty recent, so don't panic!
07-20-2009, 08:43 AM   #7
QuoteOriginally posted by GLXLR Quote
Thanks for the help... but I must say that I am even more panicking. lol. My problem is different from what you guys experienced. My lenses stay open all the time, no matter what setting/mode, or aperture on the aperture ring. I'm thinking it's stuck at wide open for all lenses except my DA*. My DA* actually works as it should (thank God!). I just covered a concert last night without a problem, but still my FA and manual "A" lenses don't stop down
aperture, camera, contacts, da*, dslr, k200d, lenses, photography, shot
K200d and weird non working aperture. zelovoc Pentax DSLR Discussion 3 12-13-2009 02:38 AM
K200d aperture problem steveuk30 Pentax DSLR Discussion 3 10-29-2009 09:23 AM
Can I get Aperture 1.5 to work with K200D? mdlarsson Digital Processing, Software, and Printing 6 08-12-2009 01:11 PM
K200D Problem with aperture ring g-kun Pentax DSLR Discussion 7 08-09-2008 08:13 AM
Blue screen in Aperture (K200D) 4.11 Alan 2 Digital Processing, Software, and Printing 5 06-12-2008 11:05 PM
All times are GMT -7. The time now is 06:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
