07-23-2009, 02:40 AM   #1
K20d..improved IQ.
I"m in Australia and the sun here doesn"t shine-it intrudes even in the middle of winter !! So I"ve been doing battle in the middle of the day with deep shadows and blown highlights. Tried several things to overcome this including the use of various filters (cir.PL and grad ND) They helped but lowering the contrast 3 stops did the job really well .
It improved the IQ no end but the saturation needs bumping up 1 stop to compensate.
The dynamic range adjustment seemed to do nothing. This was in bright mode.I"ve also settled on 400 as the base iso.
All is well
07-23-2009, 03:45 AM   #2
Interesting, I might have a play. Having same issues here in Brisbane
07-23-2009, 04:34 AM   #3
A good way to avoid this issue is to shoot raw for starters and then rectify the problems in LR or PS. I use spot metering, so you can set the exposure on the bright part of the image (typically the sky or clouds) then while holding the shutter button half way recompose the shot and take the picture. The rest of the image may be under exposed but this can easily be recovered with some judicious PP while retaining the sky detail. I have had no issues with my K20 in this regard. Hope this helps. I am in WA so have the same issues but this camera seems to cope very well...good luck!
07-23-2009, 04:36 AM   #4
QuoteOriginally posted by Daveinozbikes Quote
All is well
Shooting RAW, would likely improve even more.
I didn't use it the first year of owning K10. But when I finally tried it, it wasn't hard.
07-23-2009, 04:58 AM   #5
attack11's Avatar
QuoteOriginally posted by ozlizard Quote
that's what the ae-l button is for.
07-23-2009, 11:24 AM   #6
QuoteOriginally posted by attack11 Quote
or the setting AE lock with AF lock.
07-23-2009, 12:46 PM   #7
attack11's Avatar
QuoteOriginally posted by Bart Quote
i thought that was only for matrix metering?
07-24-2009, 04:07 AM   #8
David's Avatar
All is well
Move to Tasmania
07-24-2009, 06:06 AM   #9
Not that I know: I don't find any reference in the manual of this being restricted to matrix?
Could be a 'hidden feature' though .
07-24-2009, 06:30 AM   #10
Move to Tasmania.....
QuoteOriginally posted by David Quote
Move to Tasmania
Gday David...even the K20 earns its keep there......
07-24-2009, 06:34 AM   #11
Thanks for the replies guys,,,I would add that my preferred mode is AV with the rear wheel adj. aperture and the front iso...very,very adaptable to just about any conditions (even the night with 6400 )
camera, dslr, middle, photography
The New, Improved Flickr shiner General Talk 2 08-08-2010 02:01 PM
News Internal Search Improved Adam Site Suggestions and Help 8 11-20-2009 12:34 AM
Improved Continuous AF Tracking of the K20D RiceHigh Pentax DSLR Discussion 41 03-19-2008 08:39 PM
Improved AF Accuracy of the K20D (Under White Lights Only) RiceHigh Pentax DSLR Discussion 26 03-18-2008 11:06 AM
New and improved (CR) Needed Photo Tramp Post Your Photos! 5 09-25-2006 04:57 PM
All times are GMT -7. The time now is 04:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
