WOW, I am blessed for the magnitude of responses here! Although there are conflicting opinions in some areas (soft images at wide open apertures), it’s all good stuff because I clearly need to do several experiments to eliminate different possibilities.
I’ve noticed this problem more and more recently, then of course it’s only recently that I started to get paid for my work .. so of course when I have a paying client, I get even more frustrated when I have lost shots!
This weekend, I will be going to Central Park for the day (I live in CT) and will do lots of experimenting while taking careful notes.
Originally posted by Ash I agree this has less to do with wide open softness as it has to do with an AF calibration problem with these lenses. At 100%, you wouldn't see any detail in these shots - they're just all OOF. Does this happen with all your lenses, Lori? Has this just started happening? Anything different about your lenses?
It has not “just started”, but lately has seemed to have gotten worse. I only use these two lenses, but do have the kit lens and a 50mm/f1.8 manual focus .. I will try them ALL this weekend to see if I get different results. I also need to go through my recent series of images and look to see when it has/hasn’t happened (comparing EXIF data)
Originally posted by GeneV The last time I got results like that it was because I had turned the autofocus off.
Hmm, do you mean the lever on the front .. the AFS/AFC/M lever?
Originally posted by creampuff If you're using the K10D, don't rule out the need to send it in for focus calibration with the lenses you use as it has many instances of less than accurate AF focusing. Test focus by focusing manually and compare it with an AF shot, set up the camera on a tripod and aim at a known object beforehand.
Did you inadvertently switch the AF focus point?
Did you wait until the SR hand icon in the viewfinder is off before releasing the shutter fully?
Did you mistake the red AF point indicator with the green AF focus confirmation light in the viewfinder when shooting?
Too many variables so it is best you slowly weed out the possibilities.
Good points. I didn’t even notice that hand icon!! Lots of things to pay attention to this weekend .. I plan to jot down the image #s with the settings.
Originally posted by Marc Sabatella Shirt in the last looks likes simple camera shake. Others aren't reproduced large enough to tell if its out of focus or shake. I guess the question is, do you *ever* get sharp pictures, or did something go wrong in these?
I do get SOME sharp ones, relatively speaking. Never sharp enough, compared to many other’s images I study. Either I have the wrong settings, or I have a shaking syndrome I do not know of, or my camera is focusing on the wrong place … or … ??
Originally posted by aleonx3 Try using the focus point selection option instead of center focus and recomposition. If you still have problem with softness, it could likely be BF/FF issue which you can correct with the debug menu on the K10D.
Will try that, and more. FYI – I always have SR on (I forget about it, embarrassingly) … but will experiment with it on/off. Sounds like I have to lug the tripod to NYC this weekend! I’ll use my remote cable, and/or a 2-sec timer just to be sure. Thanks, everyone. I’ll post my findings!
