07-26-2009, 05:02 AM   #1
K7 and Manual Lenses
I've got a good collection of SMC-M and SMC-A lenses which I used a lot with my old K200D. My particular favourite is the SMC-M 28mm/3.5.
I've now got the K-7, but when I use a SMC-M lens, enable aperture ring, set the aperture, and then push the green button, the shots I'm getting are very underexposed. I'm having to compensate with 2 stops to get reasonable exposure. I've not had this problem with SMC-A lenses, and I didn't experience this with the K200D.
I can compensate for this with addition EV, but it's a pain. Anyone else suffering this?
07-26-2009, 05:09 AM   #2
What is the metering set to? Isn't there something about the metering can only be set to a particular type? (your query is ringing bells about this)
07-26-2009, 05:19 AM   #3
Same as I would with the K200D, set to 'M' manual, with the metering at 'green' the evaluative setting.
07-26-2009, 05:59 AM   #4
kent's Avatar
Try to turn lens in one or another direction. It helps
07-26-2009, 06:01 AM   #5
Interesting that you are getting underexposure with the K-7. I had pretty much given up using my M lenses because the exposures were so bad with the K20 - my 24mm f2.8 would give over-exposed pictures at just about all apertures and my 50mm f1.4 was inconsistent, some apertures overexposing, some under. My K-7 meters perfectly at all apertures with both lenses, so it sounds like some of these new cameras meter differently than others.
Have you changed the focus screen?
07-26-2009, 07:36 AM   #6
I've been using a range of manual Pentax lenses including some really old Asahi primes that could only have been made during the Jurassic period. I've had no problems with metering worth noting so I'm suspecting that you've either got interference from a deep dark setting, or there is something up with the particular K-7 you possess. Maybe a trip to the local camera store to try your lenses on their cameras and compare?
07-26-2009, 04:20 PM   #7
pcarfan's Avatar
QuoteOriginally posted by petercrane Quote
What are the asahi primes you've got. I bought my first one recently, Asahi-Kogaku 50/3.5 which I think is the first lens to be made. Curious to know, what others are worthy of pursuit.
07-26-2009, 04:37 PM   #8
Marc Sabatella's Avatar
QuoteOriginally posted by IainG Quote
If by "evaluative" you mean the multi-segment metering, that doesn't work with "M" lenses, on either the K200D or the K-7. On the K200D, if you have multi-segment metering selected normally, it automatically changes to center-weighted when you mount an M lens. I'd assume the K-7 is similar, but you might look into that. And do some controlled comparisons between the cameras using the same scene, same lens, etc.
02-13-2010, 03:28 AM   #9
manual lenses on DSLR
I've a couple of Pentax LX bodies (still using film and scanning to digital) with some nice Pentax-A lenses - 20mm 2.8, 15mm 3.5 plus some good Sigma lenses - 28-70 f2.8, Sigma Apo 75-300 5.6 and Sigma 400 5.6 - can I use these lenses on say a Pentax K7 DSLR? I'd appreciate any comments - thanks.
02-13-2010, 04:49 AM   #10
Rense's Avatar
QuoteOriginally posted by wibutee1 Quote
Yep! No problem (exept some metering problems probably, as described above, but these are to overcome!), this is exactely why I decided to go for Pentax!
aperture, camera, dslr, k200d, lenses, photography, smc-a, smc-m
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Pentax Km and old manual lenses: SMC Takumars & Tamron Adaptall 2 lenses Kendrick Troubleshooting and Beginner Help 10 04-14-2010 03:23 AM
Help with manual lenses on K-x stonedes Pentax DSLR Discussion 3 02-08-2010 10:31 AM
using these manual lenses on my kx Deiberson Troubleshooting and Beginner Help 18 12-22-2009 01:15 PM
Manual lenses. eccs19 Pentax SLR Lens Discussion 6 08-16-2009 07:28 PM
All times are GMT -7. The time now is 11:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
