Show Printable Version 4 Likes Search this Thread
08-07-2009, 08:54 AM   #166
What does that do, give you infinite lives?
08-07-2009, 10:23 AM   #167
WheresWaldo's Avatar
Just a point of clarification. I had to post this at DPR since some did not understand that some of the MODSET commands are sticky.
Once debug is enabled it stays enabled until you disable it. It survives power cycles and does not need to be reloaded each time.
I just tested scripting and it works the same way, once enabled it works every time without re-enabling it. So all you need to do is load the MODSET file one time enabling scripting, then any card that has a AUTORUN.xxx file on it will run at start up without use of the MENU button. Try it yourself it does not appear to change any other functionality other than allowing a short BASIC script to run at camera boot.
08-07-2009, 10:34 AM   #168
Thanks for clarification for ordinary users.
We also must expiriment with BASIC if we could make it background task (USING WAIT, INTERVAL, etc). Most probably it is not possible at this time.
I finished disassembling functions at second TBR (CPU Firmware).
We don't have any text at CPU part, so it is quite hard to understand functionality.
But we are now at exactly same state were last attempt by Rule 34 and other guys was abandoned. :-)
08-07-2009, 10:49 AM   #169
Rule 34...wut?
08-07-2009, 10:55 AM   #170
QuoteOriginally posted by PNTXFTW12 Quote
Rule 34...wut?
Just guy at DPReview who did some hacking efforts in 2007. Some others helped, but without any meaningful progress. I have his quotes and links at my site.
08-07-2009, 05:31 PM   #171
falconeye's Avatar
QuoteOriginally posted by tr13 Quote
Just buy Hiew license in this case!
P.S. Nasty humor again :-)
So, I now purchased the Hiew license!
@tr13, the license file is underway and I'll keep you informed by PM.
@everybody else, find another option to donate
08-07-2009, 05:41 PM   #172
falconeye's Avatar
You could try DISABLEBLC.
ALso try to write [DISABLEBLC] like im previous file.
My guess why it didn't work:
The function isn't called NR within firmware at all. I guess, it is either "DFS" or "Bulb Dark", judging from strings found so far:
DFS Offset
[Bulb Dark Interval Time (ms)]
[Bulb Dark Last Time (ms)]
[Bulb Dark Time (ms)]
08-07-2009, 05:58 PM   #173
Dark Frame Substraction ?
08-07-2009, 06:03 PM   #174
falconeye's Avatar
QuoteOriginally posted by darky_mtp Quote
darky_mtp, welcome to the forum! Enjoy your time.
Yes, DFS is the standard abbr. for dark frame substraction. Why I wondered if the "long exposure NR" found in the Pentax menu may be called differently in the depths of the firmware, like in dfs or bulb dark.
08-07-2009, 06:10 PM   #175
COLOR 4; Use red for print command.
ALLCLR; Clear the screen. What about CLS ?
PAUSE; Wait a key.
I failed to use WHILE,IF.
08-07-2009, 07:56 PM   #176
Class A's Avatar
QuoteOriginally posted by WheresWaldo Quote
This means you could a different script at each for your SD cards that will make them identify them themselves once you start the camera. No need to check the card slot anymore in case you have some many as to get potentially confused which one you are using at the moment.
Perhaps the keyboard commands could be used to establish start up macros, e.g., for resetting the camera to some customs settings?
08-07-2009, 08:06 PM   #177
Class A's Avatar
What do you think about the possibility that DISABLEBLC could mean "disable black level correction/compensation" ?
08-07-2009, 08:31 PM   #178
Thanks! As I use free hiew version at this time, just because it is best tool for a task. At least, I work with it, let me remember, like from 1989 :-)
08-07-2009, 08:38 PM   #179
Thanks for good idea. We must try previously provided extra commands.
May be WAIT 4WU will work? :-)
We also must check BASIC and other script languages documentation to provide users fully correct usage syntax.
We completely forget about Cam-Control_V2.dll so if anyone with x86 asm knowledge could help he could use free IDA version to look at functions of this DLL and their usage in service software we have.
As I understand tethering is possible on all cameras via "CamGetJPGMainMemArea", "CamGetRAWMemArea" and similar functions.
08-07-2009, 10:46 PM   #180
Some info about GX20 v1.01 and MODSET and AUTORUN functions.
MODSET works with turning on with open or closed (!) SD door (without any buttons).
You must not have AUTORUN.xx for MODSET to work :-)
All commands seems to work.
[VLENS_CTRL] displays VLENS CONTROL on screen and do not react to keys I tried. We must find key combination that toggles SDM On/off and PZ On/Off. As they are in the same assembler function :-)
[OPEN_DEBUG_MENU] Opens large debug menu on startup there you can make all functions. Like dumping your lens ROM. :-)
Especially interesting is AF PINT DISP as it displays some displacements.
AUTORUN works on every camera start, and in case of synax error it hangs sometimes :-)
Extra info, you could use FILEOUT "STRING" to write STRING to CHKDAT.xxx file. String will be appended to end of file.
WAIT without parameters causes syntax error.
With any parameter it wait indefinetely. Parameter may be TaskID.
You could also note that interpreter runs in his own thread, at least AF and metering works perfectly :-)
camera, check, dslr, firmware, fr, ida, information, k-x, pentax, photography, pm, post, progress, script, site, software, update, ver, version
DFS hack eccentricphotography Pentax DSLR Discussion 24 10-12-2010 11:08 AM
Yet another hack job -- OM to PK ?? RioRico Pentax SLR Lens Discussion 15 10-07-2010 07:49 AM
K20D Firmware Ver - Pentax Web Site Ver? ChipB Pentax DSLR Discussion 2 02-23-2010 04:14 PM
Teleconverter hack? Raptorman Pentax SLR Lens Discussion 4 01-20-2010 03:51 AM
News Site News and Site Suggestions hidden from guests Adam Site Suggestions and Help 0 11-30-2009 12:38 AM
All times are GMT -7. The time now is 06:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
