Originally posted by pentup I was hoping possibly to try debug mode to adjust focus on the K-7 past -10. I guess that isn't possible, since I find no info on hacks for the version 1.03 firmware. Just as well I suppose, since I don't want to void my warranty, but...
Has anyone used debug mode with the K-7?
I accessed it on my K-7 v1.03. Just use the same instructions as before. The AF adjustment method is the same AFAIK.
Put this in the MODSET.474 to enable the AF adj. menu:
Code:
[DEBUG_MODE EN]
[SW_DEBUG_MENU EN]
Start up with the MODSET.474 file and the card door open; wait a few seconds then turn it off and close the card door. Then start it again and press the menu key.
The test mode menu is right after the wrench menu, but it's not visible until you hit it. Once there: Test Mode > AF Test > FocusCorr
I guess you'll have to dig through the thread for more FocusCorr info since I don't know anymore & lack a lens to really test this with ATM.
PS: While in debug mode you can still take pictures (to test the AF, whatever). But you might have to press the Info button to get to the Info screen since it gets replaced by a black 'DEBUG MODE' screen.
After you're done, replace the earlier text in MODSET.474 with the lines below and start the K-7 with the card door open. Wait, and then turn it off & close the door again.
Start up the K-7 again; it should operate normally. You can delete the modset file if you want to keep your sd card neater, but it's innocuous in its current state
Code:
[DEBUG_MODE DIS]
[SW_DEBUG_MENU DIS]
Unfortunately, Pentax-Hack appears now to be Panasonic-Hack :/
