07-26-2009, 08:15 PM   #1
How do you know that SR is working?
K-m and other models: If the settings do not prevent SR from working (e.g. when on self timer), and the SR 'hand' is displayed, how do you know that SR is working (that the sensor frame is moved when the shutter is released)?...Chris
07-26-2009, 08:46 PM   #2
PentaxPoke's Avatar
QuoteOriginally posted by kitkat Quote
the only way I know of for sure is to use live view. Then you can see it working.
07-26-2009, 10:32 PM   #3
jky
I've read somewhere on the net that SR takes a split second to work after you depress the shutter button... although I haven't yet tested this.
07-26-2009, 11:13 PM   #4
alessandro63's Avatar
- When the green hand is displayed, it is always expected to work.
- If the shutter time is long enough, you'll hear a "buzz". The same buzz you hear when SR is active in live view.
- I think the info is in the exif too.
- Shoot at you with a long shutter time, without lens, with SR active (you'll have to tell it which lens you are using, cause it thinks you have a manual one mounted: insert any value). You'll see the sensor moving trying to keep a stable position while you move.
Did I answer your intended question?
Alessandro
07-27-2009, 08:23 AM   #5
Marc Sabatella's Avatar
QuoteOriginally posted by jky Quote
If you've half-pressed the shutter and waited for the "hand" icon to appear in the viewfinder, SR is on and works instantly upon pressing the shutter the rest of the way. If you don't half press and wait for the hand icon, you probably aren't getting SR.
07-27-2009, 09:13 AM   #6
Lowell Goudge's Avatar
while you may or may not notice the little hand, one sure fire way is to turn it off, and change no other settings, then just look at your images. chances are they were sharper before you turned it off
07-27-2009, 09:15 AM   #7
ryan s's Avatar
Hit the digital preview on a longer exposure like .3" then take a real picture (after waiting for the hand)...then you can see the difference
07-28-2009, 09:27 PM   #8
Good point, I never thought of that.
I don't know if EXIF info, could show if SR has been on
07-29-2009, 10:03 AM   #9
It does. Not all EXIF-displaying programs know about those fields, since they are Pentax-specific, but I believe the Pentax browser software will tell you.
07-29-2009, 11:01 AM   #10
eyou's Avatar
you realize its working when you can take pictures longer than 1/30 of a second and they are not blurry from camera shake.
07-30-2009, 07:55 AM   #11
or do what janneman does. get on a riding mower and fire away
camera, dslr, photography, sr
K-X sr working? bullwhip Pentax DSLR Discussion 6 01-20-2010 12:44 AM
survey: batteries working/not working with the K-x noou Pentax DSLR Discussion 25 12-03-2009 02:43 PM
Is SR working? Deni Post Your Photos! 6 06-21-2007 05:03 AM
SR working or not. clarenceclose Pentax DSLR Discussion 10 12-20-2006 07:58 PM
All times are GMT -7. The time now is 01:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
